Old Jun 12, 2006, 12:17 PM
HelloScott is offline
Find More Posts by HelloScott
SSMA #01M9382, AMA #137824
HelloScott's Avatar
United States, IN, Brownsburg
Joined Apr 2006
Aero Gloss Dope Thinner?
I've got a bottle of Aerogloss Dope - Clear. I need to thin it 50/50 to paint my PP One Night 28 free flight model. I don't have a hobby shop near me. The jar says to "only use Aerogloss Thinner" with their product.
Anybody know if this is true? Can't I just use some Acetone?
Anything else I can use other than Dope that I can find commonly at the hardware store?
Please post reply!
Scott
HelloScott is offline Find More Posts by HelloScott
Old Jun 13, 2006, 12:38 AM
gossie is offline
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
Yes, acetone will thin it okay, but depending where you live, if it's a high humidity area then the dope may blush when applied. Blush is to turn white and streaky.
l use thinner from local hardware store, but add a little retarder thinner to slow the mix down, so it does not blush. Retarder available at a good paint shop, or an auto repair paint retailer.
50/50 l find about the right mix too.
gossie is offline Find More Posts by gossie
Old Jun 13, 2006, 05:22 AM
McGiver is offline
Find More Posts by McGiver
NSWFFS
Richmond NSW Oz
Joined Apr 2005
If you're talking acrylic laquer thinners Gossie that's not readily available in many US states thanks to the EPA.
Retarders are available for both nitrate and butyrate dope though. A Google search should help or ask your LHS to order it in.
McGiver is offline Find More Posts by McGiver
Old Jun 13, 2006, 07:53 AM
HelloScott's Avatar
Joined Apr 2006
Thanks for the help guys...
Thanks for your help guys on the subject. I'll try a little Acetone thinned dope on a test area. I'm trying to avoid the 40 mile trip to the hobby shop.
Old Oct 22, 2009, 01:40 PM
ir3 is offline
ir3
Find More Posts by ir3
ir3
Joined Dec 2007
Thinning Aero Gloss Dopes
For what is's worth, if you are able to obtain Methyl Ethyl Ketone in your state (avail. in California) this is the base solvent for Aero Gloss dopes. It is available at most hardware stores. Use in a well ventilated area.
Regards,
IR2
ir3 is offline Find More Posts by ir3
Old Oct 23, 2009, 12:18 AM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
I have used Sig thinner with Aerogloss with good results. Do a test of whatever thinner you use. I tried to clean Aerogloss clear out of a spraygun with hardware store laccquer thinner, and made grey cloudy jello.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Oct 28, 2009, 11:12 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
If your dope application does cause blushing with white spots brushing on fingernail polish remover afterword will get rid of it.
Kev
kevin matthews is offline Find More Posts by kevin matthews
Old Oct 29, 2009, 11:06 AM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
Or, just use the finger nail polish remover as the thinner, as it is acetone and tolulene.
Here's a rundown, on the properties of basic solvents:
Aerogloss is tolulene-base. Tolulene works well, as a thinner, but allows blushing, due to its low evaporation point. Acetone is about the same.
MEK (Methyl Ethyl Ketone) works well, without blushing, as it has a higher evaporation point. The killer is that the smallest quantity it comes in is 1 gallon.
Hunt around in your area for an EAA chapter. Check with them, for some one that is doing, or has finished, a "tube & fabric" plane. If they are using the Randolph's system, they may have all the thinner, and retarder, you would need.
Kev
challenger_i is offline Find More Posts by challenger_i
Old Oct 29, 2009, 12:26 PM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Originally Posted by HelloScott View Post
. I don't have a hobby shop near me. Scott
There's a Hobby Lobby close to you in Avon, they carry dope and thinner on thier modeling isle.
Majortomski is offline Find More Posts by Majortomski
Old Sep 12, 2015, 09:38 PM
retro7610 is offline
Find More Posts by retro7610
Joined Mar 2015
Glad you got it working. Remember that auto retarder works great with dope and is cheap. I use PPG 602. There are several you can use. some are hotter and some are cooler. For model airplane applications cooler is usually best.
retro7610 is offline Find More Posts by retro7610
Old Sep 21, 2015, 05:39 PM
Louierc is offline
Find More Posts by Louierc
Just Plane Nuts
Louierc's Avatar
USA, NC, Southern Pines
Joined Dec 2008
Tower has it in stock, along with sanding sealer and clear.
Louierc is offline Find More Posts by Louierc
Old Sep 21, 2015, 08:08 PM
dan berry is online now
Find More Posts by dan berry
Joined Nov 2012
DuPont 3608S Acrylic lacquer Thinner.
At the car paint store.
dan berry is online now Find More Posts by dan berry
Old Sep 22, 2015, 08:40 AM
ddock is offline
Find More Posts by ddock
United States, MI, Stevensville
Joined Apr 2003
thinner
Agree with Dan...Have used the Dupont for a long time...Got the tip from Hank.
Denny
ddock is offline Find More Posts by ddock
Dope thinner gcedillo Free Flight 19 Nov 16, 2005 09:55 PM
For Sale Aero gloss & Formula U Paint dshly Aircraft - Fuel - Airplanes (FS/W) 1 Nov 06, 2005 07:45 PM
Alert Aero Gloss Dope and sealer 1987tc Aircraft - Fuel - Airplanes (FS/W) 1 Feb 14, 2005 03:16 PM
Dope thinner highace1 Parkflyers 7 Dec 02, 2004 06:09 PM
newbie Q: Dope thinner replacement ?? mosquito Electric Plane Talk 5 Jan 19, 2002 11:08 AM
