I'm not a Ford guy but some 3.4L Toyotas have flywheel(flexplate)cracking issues.
This may be putting the torque convertor (bushing in the crankshaft????) in a binding(squealing, grinding) situation. Remove the inspection plate between the engine and trans and check for rust or metal shavings. Usually it will change pitch when shifting between D or R if it's cracked. Good luck, Chris |
Zebulon, NC
Joined Aug 2000
Try cleaning or replacing the idle air control valve.
http://www.explorerforum.com/forums/...&highlight=IAC |
Good news/bad news: Using the mechanic's stethoscope, I finally found the location of the noise. It is a cruel place. It's coming from a tight area deep in the narrow space between the manifold/block and the firewall. I get very good audio pickup when I touch the area that is just behind either valve cover. My factory manual shows the oil pump and rear camshaft bearing in that general area. Not sure, but perhaps the timing chain is back there too? This is starting too look like a ugly repair. I sure wish I knew the exact item that is squealing so that I can determine how urgent the problem is. |
The noise does not come from the bell housing area (I carefully probed that area). It seems to be strongest at bit higher up, mostly at the manifold/block juncture. I believe the CID sensor (includes oil pump drive) is nearby, but the area is too tight to see/probe it.
I have a feeling that unless this is a common problem on this model, the fix will involve a blind tear down. I'm getting a very bad feeling about this one. Quote:
Getting closer: I found that the noise source is coming from the CID sensor. This part is located in an area that cannot be seen. It is at the rear of the block under the intake manifold. I had to feel for it with my fingers to navigate the stethoscope on it.
I called the local ford dealer and they mentioned that the drive shaft to the CID sensor is prone to failure, which they claim often harms the sensor. Parts for both is over $300. If they install it, add another $300-400 for labor. Here is a picture the sensor (see page 6, round black part under "RTV"): http://www.ford-trucks.com/lc/lc.php...eplacement.pdf Replacing it looks interesting. Has anyone here done this on the 4.0L engine? Just looking for tips in case I decide to do it myself. |
Added note about the sign up.
EDIT: Yup, search works only if registered. I found a few folks with my CID sensor assy noise problem. No luck in getting tips on how to replace it. Quote:
After doing some searching, I think the dealer guessed wrong on their over-the-phone repair estimate. Aftermarket pricing for the assy is ~$350 and dealer cost is ~$550. I think they were thinking of the 3.0L engine, which would be a breeze to work on. On the 4.0L, the part is in a nasty place. I probably won't tackle this myself unless I can find someone that has done it and can offer some advice on doing a DiY repair. The factory manual has some details, but real world experience would be nice. |
| Thread Tools | |
| Discussion Any Email 'Experts' out there? | aviatordave | Life, The Universe, and Politics | 2 | Aug 03, 2006 12:33 PM |
| Discussion Any dog experts out there ? | Al Dente | Life, The Universe, and Politics | 19 | Jan 31, 2006 10:13 AM |
| Any 9303 experts out there | jdcook54 | Slope | 0 | Nov 19, 2004 07:25 PM |
| Any Smoke Experts out there? | Jim T. Graham | Fuel Plane Talk | 2 | May 30, 2003 01:46 PM |
| Any brushless experts out there? | Parkflyer | Power Systems | 4 | Nov 26, 2002 09:13 AM |
