Joined Jan 2002
Enerland 3300 20C, CBA & 10X Curent Amplifier Graph
This is a relatively high amperage discharge graph using a CBA and West Mountain Radio 10X prototype amp. combo:
http://www.rcgroups.com/forums/showthread.php?t=528314 Pending a prospective software patch, the deicimal point must be moved one place to the right on the Amperage and AmpHours readings. |
Joined Jan 2002
e-guru
If the criterion for C-rating were to sustain an average voltage of 3.5 during the discharge, then 20C cells up to now seem to be about 11C, e.g: Post #3: http://www.wattflyer.com/forums/show...2952#post72952 Post #3: http://www.wattflyer.com/forums/showthread.php?t=6802 - RD |
Joined Jan 2002
Protocooler,
The best info I know of re pack brands containing Enerland cells: http://www.rcgroups.com/forums/showt...ghlight=brands Re their merit relative to other cells in their class, see my last post. I do plan to test more of the larger 20C cells. But variable duty cycle ("burst") discharging would have to be repeated quite a few times for an indication of LiPo lifetime. That's too time-consuming to be done manually and automatic cyclers cost upwards of twenty thousand dollars. So, I will do ten 20C continuous discharges of this Enerland cell, and others, manually. It's a tough test and should provide some grounds for inference re comparative lifespans. In any event, it's the best I can do with equipment I can afford. - RD |
Joined Jan 2002
I just noticed this morning that my results using the CBA 10X Amplifiier do not agree with Rod's (RC_Tester's) using the CamLight.
http://www.wattflyer.com/forums/showthread.php?t=3676 Possibly the cells were different, I don't know, but I believe Enerland shipped Rod's and my cells to us about the same time. Rod's test showed the cell going below 3 volts @ 18C, while mine showed it successfully completing a 20C discharge at an average of about 3.3 volts. I'll do another 20C discharge (66 amps) and check the amperage with my clamp-on ammeter. Meanwhile, I've emailed Rod. - RD |
Joined Jan 2002
The second 20C graph was consistent with the first, see attachment.
The voltage was monitored during discharge and appeared consistent with the graph; it lagged a little high compared with the CBA's voltage readout. The current (Sears Clamp-on, "Professional" model) measured 65.4 amps near the start of the discharge and drifted downwardly to 64.6 near the finish. The fact that the amperage changed indicates the CBA/amplifier combination is not perfectly linear (a stable, low amperage reading could be ammeter inaccuracy), but the overall anomaly is not nearly enough to account for the difference in results between Rod's results and mine. Gerd Giese apparently graphed this cell under the Polyquest brand, but not above 15C: http://www.elektromodellflug.de/akku-test/polyquest.htm - RD |
Just to clear the confusion - the cell data you reference is from batches manufactured late last summer, not the same as the newer cells we both have.
Enerland have stated that since December they have improced the performance of the XP cells - I think this is what we are seeing. We'll know for sure when I finish all my packing and start testing the newer batch of Enerland cells. HTH Rod Quote:
| Thread Tools | |
| Discussion CBA 10X Current Amplifier - Prototype, from West Mountain Radio | RD Blakeslee | Batteries and Chargers | 29 | Jun 10, 2008 01:29 AM |
| Data TP Extreme 2070 "25C", CBA+10X Amplifier Graph | RD Blakeslee | Batteries and Chargers | 59 | Aug 18, 2006 08:04 PM |
| Discussion Enerland 2100 20C CBA/10X Amp Graph | RD Blakeslee | Batteries and Chargers | 0 | Jun 19, 2006 10:29 PM |
| Discussion DN Power 2100 20C, CBA/10X Amp Graph | RD Blakeslee | Batteries and Chargers | 0 | Jun 18, 2006 08:35 PM |
| Data Enerland 800 20C, CBA Graph | RD Blakeslee | Batteries and Chargers | 1 | May 20, 2006 06:16 AM |
