Old Jun 10, 2006, 09:51 PM
brboy is offline
Find More Posts by brboy
Joined Aug 2005
Want to know how to make this plane a slowflyer!!
I want to know if the plane can fly slower with the wings shaped like an x. and if so how. Would like to know
brboy is offline Find More Posts by brboy
Old Jun 11, 2006, 03:24 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
If you save weight by eliminating most of the fuselage (which means "fusing" the wings and stabilizers together) and can keep the forward-swept wings rigid enough (pushing a wet noodle), that works. But for aerodynamic efficiency at low speed, you'll note that most flying animals, incl. insects, and models have wings that are neither swept foward nor back, or at least, not much! Soaring broad-wing hawks, which class includes eagles, will sweep their wings SLIGHTLY forward when circling in weak thermals to move the CG rearward and take advantage of a broader tip vortex from the forward sweep, adding efficiency at the cost of stability: they must use active stabilization, involving onboard sensors and a fast central processor whch works much faster than you could by R/C with only visual feedback and human reaction time.
I have flown numerous X-wing planes and they are fun and visually interesting, if not super-practical. Lee
xlcrlee is offline Find More Posts by xlcrlee
Any one want to try make this plane im-sad Foamies (Kits) 14 Oct 07, 2005 01:04 PM
Does anyone know how to make a prop from yogurt cartons? mortonj69 Scratchbuilt Indoor and Micro Models 39 Dec 08, 2004 09:54 AM
Does anyone know how to calibrate this scale? WilliamSettle Electric Plane Talk 3 Jan 29, 2003 08:07 AM
How will this plane fly? Mike Hall Foamies (Kits) 8 Sep 02, 2002 08:51 PM
