Jun 10, 2006, 10:00 PM
United States, MI, Chelsea
Joined Aug 2005
Here ya go:
BP 21 Outrunner Brushless Motor
Configuration:......Propeller:....Volts:......Amps :...........Thrust:
Direct Drive.........8040..........7.4V........8.2A...... .......12.0 oz / 342.86 grams
Direct Drive.........8040..........8.4V........8.6A...... .......13.8 oz / 394.29 grams
Direct Drive.........8040..........9.6V.......11.1A...... ......17.0 oz / 485.71 grams
Direct Drive.........8040.........11.1V.......13.1A...... ......21.0 oz / 600 grams
For 2-3 Li-Poly Cells (7.2-12.6V)
Recommended props: 8 x 4, 9 x 4 Slow Flyer
31 mm diameter x 62 mm length
Maximum current: 13A
Weight: 50.2 grams / 1.77 oz (everything shown in picture including gray gear box housing)
Comes with stick mount plastic frame
Firewall mount capable
Comes with two prop nuts and one washer
3mm shaft diameter
10mm x 10mm stick mount
Kv: 1750
9 Stator Poles, 12 Magnets
