Old Jul 31, 2006, 11:05 AM
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Does the CBA still not use remote voltage sensing??
Every other high-current discharger uses remote voltage sensing leads to read the cell voltage independent of current-carrying wire...
Here's an alternate idea for medium/high-current testing, and a LOT cheaper!
see: http://www3.telus.net/super_iq/iq_booster.htm
Note the 99 amp limit, not 45A, as that applies to a 6-cell NiCd pack!
An oldie, but a goodie!
P.S. Resistance drift due to the resistor heating won't matter, as the discharge current is dynamically controlled by the charger every 1/100 of a second.
meteor is offline Find More Posts by meteor
Old Jul 31, 2006, 04:01 PM
Joined Jan 2002
meteor,
The unit reads (+) at the cell tab, but reads (-) off the power lead.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Jul 31, 2006, 04:33 PM
Del Schier
k1uhf's Avatar
Joined May 2002
Hi all,
The CBA does have provision for remote sensing on the positive lead and that should be used if want to know the voltage at a cell.
You understand that the CBA and the CBA amplfier do a constant current dischage, it is electronically and software regulated.
I figure if you are using that resistor to discharge a single Nickel cell it would pull 9 amps at .9 volts. The CBA amplifer will regulate a constant 160 amps all the way down to .9 volts!
You could save $25 bucks on the resistor and use the motor in your airplane, ha.
Del,
West Mountain Radio
k1uhf is offline Find More Posts by k1uhf
Old Jul 31, 2006, 07:29 PM
California
Joined Apr 2006
Guys,
Just curious, what is your expcected sales quota per year on these 10x add-on unit? I am sure you are going to tell me it cost a lot to build one of those thing, but priced at $469 seems to suggest it's going to be a low sales volume item.
~ASM
asm_ is offline Find More Posts by asm_
Old Jul 31, 2006, 09:08 PM
meteor's Avatar
Ontario, Canada
Joined Nov 2002
You missed the point of the resistor.
The Victor IQ has six discharge FETs and can already do a 200W constant-current discharge.
The resistor is there as another dissipation point in a series circuit, you could parallel a few to dissipate more power at lower voltage levels.
The point being that there is no need to dissipate all the power through the FETs, as all you care about in testing is a constant-current drawn through the cell, not where the power is actually being dissipated!
Old Aug 01, 2006, 10:38 PM
Joined Jan 2002
The voltage difference shown in the curves of post #12 are apparently caused by the wiring runs connecting the amp beteen the CBA and the cell; see the photo in post #1.
So, curves generated by the amplifier-CBA combination cannot be overlaid with curves generated by the CBA alone, for cell comparisons.
Also, I'll take voltage readings at the cell tabs with my Fluke as the curve is generated, when it passes a graph voltage line near mid-curve, and publish that measured voltage along with the graph, so the curve's position can be mentally corrected.
- RD
Old Aug 01, 2006, 10:45 PM
Joined Jan 2002
As a practical matter, it might be useful to point out that the voltage drop caused by the test wiring runs are likely to be substantially less than those caused by the wiring in a typical model airplane.
- RD
Old Oct 24, 2006, 08:48 PM
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Its been out for a while, how do you guys like it? Is it as easy to use as CBA? How does windows application know if its going through amplifier or not?
Beta software that was mentioned previously - does it show Watt hours at last?
Hovertime is offline Find More Posts by Hovertime
Old Oct 25, 2006, 10:34 AM
Del Schier
k1uhf's Avatar
Joined May 2002
Hello all,
The special software written for the amplifier operates in exactly the same way as the CBA software. The diffference is there is an option which allows the user to set it for 10X operation (current times 10). If the user has the amplifier in line but turned off he may select no amp and the program runs as it did with just a CBA with the exception that the program asks when starting a test if an amplifier is connected and on.
BTW the amplifier graphs may be overlaid with CBA only graphs with the correct numbers.
Del Schier
West Mountain Radio
Old Oct 25, 2006, 10:58 AM
Joined Jan 2002
Works just like Del said.
For me, it's been a transparent extension of the CBA, easy to use and no more frustration trying to evaluate relatively large and/or high C-rated batteries.
- RD
Old Oct 25, 2006, 11:01 AM
Joined Jan 2002
Still need cycling capability, for battery life testing.
- RD
Old Oct 25, 2006, 12:23 PM
Del Schier
k1uhf's Avatar
Joined May 2002
- RD
FMA has a CBA working with their Cellpro charger to do automatic cycling. We are working with them to develop a system with their charger and our CBA to do a user selectable number of cycles but for now each full cycle requires a couple of mouse clicks to save the graph and start the next one.
Del
Old Oct 25, 2006, 05:42 PM
Bantam distributor
supi7's Avatar
CHICAGO
Joined Feb 2004
Del, The e-Station 902 that we distribue is capable of 5 Lipo cycles at this time. Please let us know if there is a possibility now or in the future to connect the 2 together.
The 10X been working really well for us so far, the only thing I no longer see in the update version of software is the ability to "zoom in" on the graph after the discharge.
Best Wishes,
Dan
TrueRC
supi7 is offline Find More Posts by supi7
Old Oct 25, 2006, 08:23 PM
Joined Jan 2002
Del
Great news, Del!
Will the prospective automatic cycler allow incorporation of the 10X amplifier, for high amperage discharges?
- RD
Old Jun 10, 2008, 01:29 AM
Bantam distributor
supi7's Avatar
CHICAGO
Joined Feb 2004
Del, any news on this auto cycler from WMR or FMA?
Dan
Help! West Mountain Radio CBA Owner, Help!! asm_ Batteries and Chargers 29 Aug 24, 2007 06:37 PM
Sold West Mountain Radio CBA II "Cheap" erichj Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 05, 2006 04:00 PM
Sold NIB West Mountain Radio CBA II Discharger Arthur Knowles Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 23, 2006 08:48 PM
Sold West Mountain Radio CBA II battery analyzer turbojoe Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 22, 2006 05:10 PM
West Mountain Radio CBA Pro - what new features? GBR2 Batteries and Chargers 2 Dec 26, 2004 02:00 PM
