Joined Jan 2002
CBA 10X Current Amplifier - Prototype, from West Mountain Radio
This amplifier is a welcome extension of the CBA's usefulness as higher-powered LiPos come to market. It's very straightforward to use - simply connects in series between the battery and the CBA. The production unit will have a cover.
The software has not been patched for the amplifier yet, so the current settings, which are by means of the CBA's usual software, have to be set @ 1/10 the actual amperage and the corresponding mAh readings are one decimal place low. Until the software is patched, Overlays of the graphs generated on the CBA alone cannot be overlaid on graphs made with the amplifier - the graphs are also off by a factor of 10, of course. See the graph. I'll graph the Enerland 3300 20C shown, out to 20C (66A), and publish it in a separate thread shortly. (Edit, 6/12: http://www.rcgroups.com/forums/showthread.php?t=529118 ). - RD |
Joined Jan 2002
Hi Tom,
It seems to work well: http://www.rcgroups.com/forums/showthread.php?t=529118 Rather than guestimate the production model's price, I'll ask Del Monday. World Hobby, It's my understanding that the first batch of production models will be avaiable quite soon. The folks at West Mountain Radio could tell you. - RD |
RD,
For graph overlays, you could export the data into excel, multiply the numbers out and then graph. I have used this method in the past and works pretty good. 2dogrc |
Latest blog entry: Huge Fathers Day, Some Items 1/2 Off!
The CBA Amplifier is on our web page:
http://www.westmountainradio.com/CBAAmplifier.htm Dave has a prototype but we are shipping the first production uints now. We have a long first come first serve list so we do not want to put them on the web page. The page processes charge cards before we ship. If you would like to be on the list, email me. We contact you when one is ready according to the list. Thank you, Del Schier West Mountain Radio 18 Sheehan Ave. Norwalk, CT 06854 http://www.westmountainradio.com tel: 203 853 8080 fax: 203 299 0232 Quote:
Actually the 0.8 volt 160 A is not a limit, it is a spec.
The limit depends on ohms law. With a "perfect battery" the Juicer may do 200 amps. We do have it fused for 180 amps but a battery would be dead before you could blow those fuses at 200 amps. We have an FET "on" resistance plus other circuit resistance inside our product. Add the internal resistance of the battery and the associated connections and by ohms law that limits the maximum current. Below a voltage where our FETs are full on, in order to regulate the current below that voltage we will no longer be able to regulate a constant current. Our tests with a GP 3300 160 A shows that 160 amps is a reasonable typical spec. That doesn't mean you can't pull higher current from some other cell at a higher voltage. Of course you should not exceed the 500 watt continuous limit for the system. If it wasn't for ohms law you would be able to pull 500 amps from a 1 volt cell BTW as soon as we catch up on orders we plan to have a kit for two amplifiers in series parallel for 1000 watts and double the current (half the resistance). I hope this makes sense. Thank you, Del Schier West Mountain Radio 18 Sheehan Ave. Norwalk, CT 06854 http://www.westmountainradio.com tel: 203 853 8080 fax: 203 299 0232 Quote:
| Thread Tools | |
| Help! West Mountain Radio CBA Owner, Help!! | asm_ | Batteries and Chargers | 29 | Aug 24, 2007 06:37 PM |
| Sold West Mountain Radio CBA II "Cheap" | erichj | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Nov 05, 2006 04:00 PM |
| Sold NIB West Mountain Radio CBA II Discharger | Arthur Knowles | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Aug 23, 2006 08:48 PM |
| Sold West Mountain Radio CBA II battery analyzer | turbojoe | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | May 22, 2006 05:10 PM |
| West Mountain Radio CBA Pro - what new features? | GBR2 | Batteries and Chargers | 2 | Dec 26, 2004 02:00 PM |
