Old Jun 09, 2006, 12:42 PM
supi7 is offline
Find More Posts by supi7
supi7's Avatar
CHICAGO
Joined Feb 2004
New Product
70mm and 90mm EDF units available for Brushless
70mm and 90mm fan units are available at www.TrueRC.com (esc and motor section)
Best Wishes,
Dan
TrueRC
supi7 is offline Find More Posts by supi7
Old Jun 09, 2006, 03:02 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Ok show us, they are apparently not on the site.
Eric B.
AirX is offline Find More Posts by AirX
Old Jun 09, 2006, 03:05 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
Try this link and scroll all the way down
http://home.comcast.net/~truerc/esc/escNmotor.htm
If you still do not see them press F5 to refresh your browser
Dan
Old Jun 09, 2006, 03:06 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
bottom of the page
rcguy01 is offline Find More Posts by rcguy01
Old Jun 09, 2006, 03:09 PM
Cyberman is offline
Find More Posts by Cyberman
Mad Max meets the Thinker
Cyberman's Avatar
Pittsburgh, PA
Joined Apr 2004
Eric B.
You click the Esc and Motor link and they are at the very bottom
Cyb
Cyberman is offline Find More Posts by Cyberman
Old Jun 09, 2006, 03:11 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Ok I see the airpower fans.
Eric B.
Old Jun 09, 2006, 05:57 PM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Anyone tried one of these yet?
Matty
Psionic001 is offline Find More Posts by Psionic001
Old Jun 09, 2006, 07:40 PM
Keithf is offline
Find More Posts by Keithf
Keithf's Avatar
Sydney, NSW, Australia
Joined Oct 2000
Interesting that the 90mm fan shows thrust at maximum power is 20N, which is about 4.4 pounds. It then says that its capable of over 5 pounds of thrust. Unashamed hype?
Keithf is offline Find More Posts by Keithf
Old Jun 09, 2006, 07:52 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
I have seen some tests from others that substantiate thier claims but it will take a heavy motor to dissipate the heat from the watts absorbed from efficiency losses.
Eric B.
Old Jun 09, 2006, 08:39 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
We would not dare to BS. Its proven results.
Dan
Old Jun 09, 2006, 11:45 PM
akelelias is offline
Find More Posts by akelelias
akelelias's Avatar
United States, TX, Fort Worth
Joined May 2006
Read review/test from the link below
http://www.airpowernet.com/twe/produ...6b95c63f338937
It produced 5.1 lb
akelelias is offline Find More Posts by akelelias
Old Jun 10, 2006, 01:42 AM
AirPac Models is offline
Find More Posts by AirPac Models
AirPac Models's Avatar
Honolulu, HI
Joined Nov 2004
We have both AirPower 70mm & 90mm. The 90mm can produced 100oz (6.24lb) or more thrust.
This is another review
http://www.wattflyer.com/forums/show...?t=5648&page=2
AirPac Models is offline Find More Posts by AirPac Models
Old Jun 10, 2006, 04:41 PM
rcguy01 is offline
Permanently Banned
Joined Apr 2003
any review on the 70mm fan?
Thanks.
Old Jun 10, 2006, 07:47 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
I am working on building an EDF thrust stand.
I tested 70mm EDF with 10V motor driver and our 450TH 2950kv motor
at full throttle (using the software from our STORM ESC) it delivered 20+ oz of thrust JUST BLOWING AT THE SCALE
I will get some more accurate results soon.
Dan
Old Jun 10, 2006, 07:55 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Well if your going to test, do it right. Aiming the efflux at the scale is the wrong way to test mainly because it introduces a pressure component to the physics that is not present in a flight configuration. Make a stand that will focus the efflux away from the scale so the fan is pushing towards the scale and you will be measuring exactly what is being produced as thrust and not because of a deviation of pressure.
Now if you want to test me on this just point the efflux at the scale and move it 6 inches away from the scale and then move it 2 inches away from the scale the weights the scale will measure will be different becuase a difference in pressure(expansion of air in all directions). Now take and make a structure to hold the fan pointing the efflux away from the scale and measure it force, move it 6 inches away from the scale and it will be the same force, hence no pressure change inttroduced into the physics making the thrust.
Eric B.
Data Test data for DIY brushless motor kits for use in the Alfa, XF, and GWS EDF units The Don Electric Ducted Fan Jet Talk 245 Aug 23, 2007 02:33 AM
Sold 2 AirPower 90mm fan units $65 for both speleopower Aircraft - Electric - Power Systems (FS/W) 1 Dec 25, 2005 08:42 AM
Kamdax vs Wattage which EDF is a better platform for a Brushless upgrade? Tommy D Electric Ducted Fan Jet Talk 11 Jan 31, 2005 10:43 PM
Looking for EDF Units and cobalt and brushless motors Jodie Aircraft - Electric - Airplanes (FS/W) 0 Mar 26, 2003 06:37 PM
EDF Units for Team Orion Elite Modified Motor? nolasco Electric Ducted Fan Jet Talk 0 Mar 11, 2002 11:52 PM
