Old May 01, 2001, 10:20 AM
Patrick is offline
Find More Posts by Patrick
Bellevue, WA, USA
Joined Nov 2000
B-2 motors amp draw
Does anyone know off hand what the amp draw would be for the following set-up, 4 stock B-2 motors, stock props, and a 7 cell 270mah pack. Also any estimates on thrust.
Pete
Patrick is offline Find More Posts by Patrick
Old May 01, 2001, 11:13 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hi Pete,
I have modified my B-2 to 4 motors and use 6/250mAh instead of 6/110mAh. I have not measured thrust or current, but I can climb at a constant 30° angle with a model weighing 185g and I am still using my schulze slim-8e ESC. Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 01, 2001, 11:17 AM
Patrick is offline
Bellevue, WA, USA
Joined Nov 2000
Thanks Jurgen!
That works for me! How/where did you mount the extra motors?
Pete
Old May 01, 2001, 11:43 AM
Patrick is offline
Bellevue, WA, USA
Joined Nov 2000
Once last question, does anyone know if the stock B-2 motors and props would work as good in a tractor setup? Maybe use two as pushers and two as tractors.
Pete
Old May 01, 2001, 02:54 PM
Joined Sep 2000
I added two more slots (similar to the original ones) right next to the inner ones. Pusher props are more efficient! Jürgen
Old May 01, 2001, 02:57 PM
Joined Sep 2000
Oops, by the way, 7 cells is too much for the motors and the 270 way too heavy. 6/220 - 6/250 is the way to go! Jürgen
Old May 01, 2001, 08:25 PM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Patrick/Jurgen
Been using 3 Tadirans for 2 B-2 motors (pusher) in a small (own design) 170g Biplane for some time without any problems. Tried both 6 and 7 cell packs also. 6 didn't have enough zip, 7 was Ok but didn't last very long. Haven't kept a log on it but would guess at least 2.5-3 hours on the motors, but never run for more than 10-15 min. at a time. The bat don't run down in that amount of time, but I do. Never checked the amp draw.
Kern
KLH is offline Find More Posts by KLH
Old May 02, 2001, 11:49 AM
Joined Sep 2000
My B-2 with two motors weighs only 135g and has probably less drag than a biplane. Flys OK with 6/110s but two extra motors really make a difference. Rolls and loops from level flight: no problem! Jurgen
Old May 02, 2001, 09:04 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Check last motor on chart:
http://www.empsinc.com/mo_data_alpha.pdf
Dave Hederich is offline Find More Posts by Dave Hederich
FS: JKA's Big T + 2 Motors & GBs Orcoz Aircraft - Electric - Airplanes (FS/W) 8 Aug 29, 2002 08:46 PM
old Wattage B-2 motors... project? Martin Hunter Parkflyers 12 May 16, 2002 03:17 AM
gearing Wattage B-2 motors? Martin Hunter Parkflyers 2 Mar 16, 2002 11:18 AM
Where can I purchase N-20's (Wattage B-2 motors)? totalboss Electric Plane Talk 2 Sep 23, 2001 06:36 PM
Wattage B-2 motors on 7 cells? Thomas B Parkflyers 6 Jul 01, 2001 07:15 AM
