Old Jun 07, 2006, 09:24 PM
tocano is offline
Find More Posts by tocano
tocano's Avatar
Perth, Australia
Joined Sep 2003
Where can I buy EPP in Perth
Hi,
I am looking for EPP 6mm thick, not a big size. Only need 70x50 cm, but would like more if I can get it.
I am building my first 3D foamie, if I can't find EPP I will use Depron.
But apparently EPP is much stronger? I never use either so I don't know.
Can anyone tell me where I can get them in Perth?
Thanks.
tocano is offline Find More Posts by tocano
Old Jun 07, 2006, 11:29 PM
WOOSHKA is offline
Find More Posts by WOOSHKA
Aussie 3DHS Addict :-)
WOOSHKA's Avatar
Port Denison, Western Australia
Joined Jul 2005
check with grizzlymatt on this forum - i know here bought some from a guy in joondalup
WOOSHKA is offline Find More Posts by WOOSHKA
Old Jun 08, 2006, 12:47 AM
tocano is offline
tocano's Avatar
Perth, Australia
Joined Sep 2003
Yes they guy sells Depron but not EPP.
I still can't find a place that sells EPP sheet.
Old Jun 08, 2006, 01:26 AM
grizzlymatt is offline
Find More Posts by grizzlymatt
3DHS Addict DownUnder
grizzlymatt's Avatar
Perth, Western Australia
Joined Aug 2004
ozhobbys sell it have a look here
http://www.ozhobby.com/
grizzlymatt is offline Find More Posts by grizzlymatt
Old Jun 08, 2006, 04:02 AM
AXI Motor Models is offline
Find More Posts by AXI Motor Models
Expert plane crasher
AXI Motor Models's Avatar
Central Coast, Australia
Joined May 2005
You can get EPP in NZ at http://www.foamworks.co.nz/
They sell foam in 90x40cm and 6mm thickness or whatever you like and they also sell carbon rods and tubes which you would need if you made it out of EPP to make the plane rigid.
AXI Motor Models is offline Find More Posts by AXI Motor Models
Old Jun 08, 2006, 04:11 AM
tocano is offline
tocano's Avatar
Perth, Australia
Joined Sep 2003
Ok, thanks for the info.
Too much trouble ordering EPP from outside Perth.
I picked up a couple of sheets 6mm and 3 mm depron instead today from Joondalup Floor heating place.
Originally I was going to build 24" 3D plane and I changed my mind and going for the 28" wingspan instead. I hope it's big enough for Perth being so windy most of the time.
Old Jun 08, 2006, 04:30 AM
Joined May 2005
yea, wind is a problem here too
I'm still trying to find a solution to overcome the wind. Increasing the wing loading can help.
Question Where can I buy EPP in sheets? howsthewind Slope 5 Apr 30, 2006 12:50 AM
Where Can I Buy EPP Foam? Synthetic Foamies (Kits) 3 Dec 28, 2004 09:19 AM
Where can I buy a CYBIRD in OZ mrfirkin Ornithopters 6 Jul 30, 2004 02:21 PM
Where can I buy GWS in Taipei ?????? ClimaxPilot GWS (Grand Wing Servo) 7 Feb 01, 2004 04:04 PM
Where do i buy EPP in UK? Andycap Parkflyers 3 Oct 16, 2003 01:10 PM
