Oct 05, 2002, 06:45 AM
Kamloops, BC, Canada
Joined Feb 2002
Now using your favourite shrinking method, hit the wing. Shrink that puppy! You might want to repeat the solite heatgun pledge to yourself before doing so. Chanting it while using the heatgun might work too. Work your way from root to tip and back again, but don't expect all the wrinkles to come out on your first pass. If you have a stubborn one, make circles around it, and shrink the covering bordering it. That usually helps to get most of the major ones out, and then you can hit the wrinkle itself directly to tighten it up.
If using an iron on a higher low temp setting (per my above pic) you can hold it on the covering indefinately. Temps on your irons will vary, but play around with a scrap piece of covering on wood to check what the melting threshold is. After holding the iron on your area to be shrunk for a few seconds, pull it away and you should have a nice tight finish.
As a point of interest, I did the iron shrinking method on my Pup and heatgun on the Cessna. The pup I had to reshrink once, and the Cessna has stayed tight as a drum. When I did reshrink the pup, I did so with the heatgun and now it's staying tight. Thus, I use the heatgun a lot.
Here's the wing "before"
