Old Jan 11, 2007, 11:26 AM
RMac is offline
Find More Posts by RMac
Seattle
Joined Feb 2004
Thanks, do you use a sock on the iron with the Solite.
RMac is offline Find More Posts by RMac
Old Jan 11, 2007, 11:42 AM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
Always use a sock - especially with So-lite.
cadconversions is offline Find More Posts by cadconversions
Old Jan 11, 2007, 11:44 AM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Also -- change the sock when you change colors...
Red 61 is offline Find More Posts by Red 61
Old Jan 11, 2007, 11:45 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Sorry, I've never used a sock. But, I do clean the iron frequently and when changing colors.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Jan 11, 2007, 12:45 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
That's funny, I use the same sock on my iron with all colors and have never had a problem. The color doesn't transfer to the iron, so I'm not sure why you'd have to keep changing socks. Maybe you guys push down on the covering more than me or something. I just glide the iron over the surface and let the heat do the work.
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 11, 2007, 01:17 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
Yes -- the color transfers to the sock. Then, it transfers from the sock to the (other) color...
White is the worst to deal with (with yellow a close second) -- I get blue and red (and sometimes black) smudges on white and yellow all the time...
Change the sock when you change colors. Ideally, you would have one sock for each color.
Old Jan 11, 2007, 01:41 PM
Around the World
Scottsville, KY
Joined Jun 2002
Yep, the color transfers only when you are around an edge that peels back just a little. Then it really transfers once you get it on the iron to the whites and yellows.
Old Jan 11, 2007, 02:05 PM
der Oberflügel is offline
Find More Posts by der Oberflügel
Always room for improvement...
der Oberflügel's Avatar
Schertz, TX
Joined Jun 2004
I know this is a mostly a solite thread, but I've got blue and red on my sock from solarfilm, and it does come off on the white here and there, but I've never had any trouble getting the red or blue color off the white with a little 409 and a rag. Maybe solite is different? Maybe I've been lucky or something.
der Oberflügel is offline Find More Posts by der Oberflügel
Old Jan 11, 2007, 02:23 PM
Around the World
Scottsville, KY
Joined Jun 2002
der,
I only use solarfilm for everything and I'm with you, when it does get on the iron a paper towel and a little ironx (purchase from tower) and it comes off. However, it's been too long for me and so-lite to know if it does the same. I would suspect that it does.
Old Jan 11, 2007, 03:12 PM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Solite and solarfilm both do it. So do all the other coverings I've used (monokote, airspan, litespan, solartex, econokote) when you work at the edges with too much heat.
charlie
Old Jan 11, 2007, 04:07 PM
Duetto is offline
Find More Posts by Duetto
Frederick Maryland USA
Joined Jul 2004
Wiping with a little acetone on a rag seems to easily take off the transfered color.
Duetto is offline Find More Posts by Duetto
Old Jan 11, 2007, 06:55 PM
Palmettoflyer is offline
Find More Posts by Palmettoflyer
Palmettoflyer's Avatar
United States, SC, Mt Pleasant
Joined Jun 2002
My $.02 worth.
Use an old white T-shirt wrapped around the iron. No need to purchase socks. Just clean out the old undershirt drawer. Sometimes, I cut the T-shirt into smaller more manageable sections. When one spot gets messed up, just slide it over, re-twist and keep on covering.
My other $.02 suggestion or advise. Never cover without the sock or other covering. The bare iron will scratch up your covering.
Palmettoflyer is offline Find More Posts by Palmettoflyer
Old Mar 31, 2007, 12:45 AM
ShipBear is offline
Find More Posts by ShipBear
Mobile, Alabama
Joined Feb 2004
Chrome
Js there any film that looks like real chrome..??
For letters, etc.
Thanks, Larry
ShipBear is offline Find More Posts by ShipBear
For the Solite Challenged... Part II cathode Parkflyers 14 Jul 03, 2005 10:21 AM
For the Solite Challenged Post Compiled Morb Parkflyers 1 Nov 10, 2003 12:01 PM
Covering Iron for Solite? E-Minn Parkflyers 3 Oct 29, 2002 09:08 AM
Thermal for the lift-challenged... Sparky Paul Life, The Universe, and Politics 5 Sep 05, 2002 06:09 AM
switchback construction pics (not for the bandwidth challenged) Martin Hunter Parkflyers 31 Apr 16, 2002 02:42 AM
