Old Jun 06, 2006, 06:09 PM
LurchNC is offline
Find More Posts by LurchNC
LurchNC's Avatar
Joined May 2006
Springs/Diff oil for Integy Jato Shock?
Hi all
I ordered some integy Jato shocks and I would like to know what springs/oil and piston (2 or 4 hole) y'all are using. My LHS only has 30K and 50K diff oil in stock and from what I have read that is too thick. I have some 20 and 25 lb Revo springs comming as well. I'm hoping you can save me some guess work.
R.J.
LurchNC is offline Find More Posts by LurchNC
Old Jun 06, 2006, 06:13 PM
^jynx^ is offline
Find More Posts by ^jynx^
Danbury, CT
Joined Jun 2005
well I dont have a jato shock, but I am running a diratrax Maximum MT shock. It has a 2 hole piston, and I use the 50k wt diff oil. Oh yeah I am also using the stock TT psrings.
^jynx^ is offline Find More Posts by ^jynx^
Old Jun 06, 2006, 08:12 PM
swheels is offline
Find More Posts by swheels
swheels's Avatar
Joined Jan 2005
I run 10k in minds.But i also inlarged one of the piston holes.You should try the 5k or the 7k.
swheels is offline Find More Posts by swheels
Old Jun 06, 2006, 09:13 PM
mollycbr123 is offline
Find More Posts by mollycbr123
STeve B in NC
mollycbr123's Avatar
North Carolina, USA
Joined Sep 2003
I use the 4-hole piston and 7k wt. dif oil. I also run the stiffer spring (red with purple). It works well, but I haven't gotten around to shimming the shock travel properly yet.
mollycbr123 is offline Find More Posts by mollycbr123
Old Jun 06, 2006, 09:30 PM
LurchNC is offline
LurchNC's Avatar
Joined May 2006
Thanks for the replies. I will try to find some 7k diff oil and give it a shot. If not I will try the 30K Traxxas.
R.J.
Old Jun 07, 2006, 08:09 AM
WinTech is offline
Find More Posts by WinTech
Johnny in CT
Cos Cob, CT
Joined Dec 2005
I am using 4 hole, 5000wt with red spring in the electrics and 4 hole, 7000wt with blue spring in the nitros. If you are using the TT aluminum bottom mount, a perfect shim is the center plastic frame spacer from a FM-1e, it is 12mm, just drill the center a little bigger to fit the shaft. You will also need to run a 3mm tap in the mount to extend the threads a little, this will allow the mount to screw all the way onto the shaft. The bottom mount supplied with the shock is longer than the aluminum, so a bigger shim, 13-14mm is better if you want to use that. Thses shocks are the best I have ever seen, I can't believe there is an o-ring on the pistion, way cool.
-Johnny
WinTech is offline Find More Posts by WinTech
Mini-HowTo Integy MSR6 Piggyback for REVO/JATO Rear shock conversion for TTn MV Agusta Motorcycles 125 Feb 25, 2007 06:26 AM
Discussion What oil for GPM Front shock HOR us_matrix Motorcycles 7 Oct 18, 2006 11:24 AM
Discussion wht shock and what oil for it? playerpete Motorcycles 3 Oct 17, 2006 08:06 PM
Discussion What wt. oil for rear TTn shock ^jynx^ Motorcycles 16 Feb 07, 2006 09:42 PM
Question Shock/Diff. oil viscosity in cps/Wt. MiguelDK Car Talk 0 Aug 24, 2005 03:34 PM
