Otherwise it might be OK to reduce the thickness of the wood, but you generally want it thiner towards the back anyway and that post is a load carry post, so keep that in mind. Ryan Ryan |
Latest blog entry: 2012 Masters Videos
Dallas TX
The horizontal stab had the stringer on the underside for a 1/2 Diamond profile. Stiffness increased tremendously. Both vertical and horizontal fins had their chords increased by 1 inch to improve handling when flown without ballast. Technically: The empty Paragon is a floater and CG tends to be a bit forward. The tiny inverted MCL actually offsets the small download better than a flat plate. Speed runs are on rails - stabilizing the antics of a plump profile with large amounts of ballast - and tail surfaces that are not whippy. ![]() http://www.rcgroups.com/forums/showa...d=930691&stc=1 |
Mine has balsa stock sanded triangle on the sides of the fin too. Forgot to mention that. Is that not in the design?
Ryan |
Punta Gorda, FL
Joined Apr 2002
http://www.rcmmagazine.com/e/env/000...ore-plans.html
"Plans for each construction article featured in R/C Modeler Magazine." PARAGON Our Price $14.50 by Ed Slobod, 118" span, 1080 sq. in., 2 ch., built-up balsa, plywood, and spruce, two sheets 27" x 52", 34" x 52", Issue: RCM 1-76 And MIRAGE Our Price $14.50 by Blaine Rawdon, 112-1/2" span, 915 sq. in., 2 ch., built-up balsa, plywood, and spruce, two sheets 22 -1/4" x 50-1/2", 32" x 49-1/4", Issue: RCM 2-79 |
arukum17,
I used this link to order my Paragon and it came with full plans and instructions. http://home.comcast.net/~bsli40/Specials_page.htm John |
| Thread Tools | |
| A question for the Filip 600 proud owners | RookieOne | Electric Sailplanes | 13 | Sep 30, 2003 04:13 PM |
| Zagi THL or Zagi LE or any other epp wing glider | Nik-rc | Aircraft - Sailplanes (FS/W) | 3 | Jun 12, 2003 10:28 PM |
| WTB: Zagi THL or Zagi LE or any other epp wing glider | Nik-rc | Aircraft - Electric - Airplanes (FS/W) | 3 | Jun 07, 2003 03:04 PM |
