Old May 01, 2001, 09:52 AM
ChrisD is offline
Find More Posts by ChrisD
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
Foam cutting - electronics question AC to DC
I made a power supply for a foam cutting bow using a ceiling fan speed control and a Radio Shack 2 amp transformer. The transformer output is 24 volts AC at 2 amps. I tested the setup yesterday with a .022 diameter stainless steel fishing line. Works great in test, but not sure how it will work on a 24" wing core.
My question - should I put a bridge rectifier and a couple of capacitors on the output of the transformer to convert it to DC? Will this make a difference in wire temperature/amp draw???
I've read all the posts about using a car charger, ESC/Nicad pack, variac, feathercut etc. already, and they are next on the list of options. Total cost - $20 in parts.
Thanks, Chris
ChrisD is offline Find More Posts by ChrisD
Old May 01, 2001, 09:57 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
AC heats things up just as well as DC, after all electric fires work on house AC. There's no value in complicating it further. The only thing I'd be a bit wary of is the 2A transformer. The rating seems a little low, I'd check from time to time to see if it's getting hot !
Steve
steve lewin is offline Find More Posts by steve lewin
Old May 01, 2001, 10:01 AM
ChrisD is offline
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
Thanks, Steve,
I don't expect the cuts to be that long in duration, or making lots of them. The transformer was $9.99. I'll give it a shot.
Chris
Old May 01, 2001, 11:58 AM
yb2normal is offline
Find More Posts by yb2normal
Frequent User
yb2normal's Avatar
Broomfield, CO, USA
Joined Jan 2001
The primary advantage of a DC voltage is safety... AC voltage travels through your body much more efficiently.
I combined a couple of the suggestions from ezone (including yours interestingly enough), and plugged a cheap car battery charger into a high power light dimmer... The result is safe, isolated DC current, and as a bonus I can read the current draw off the meter on the charger. I simply adjust the light dimmer until the charger says that I'm drawing about 4 amps, then start cutting.
yb2normal is offline Find More Posts by yb2normal
Old May 02, 2001, 12:28 AM
ChrisD is offline
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
YB2Normal,
Hey, I've got a 12v Deep Cycle 10 amp charger as well.
I thought about it, but dismissed the idea because I couldn't control the amperage. Your solution sound great. I'll try it with my fan control. Yes, the charger has a meter as well. It didn't dawn on me to use it. duh!
Chris
Old May 02, 2001, 05:11 AM
JP is offline
JP
Find More Posts by JP
JP
Portugal
Joined Mar 2001
I don't think 2A@24V is short. I use a 70 cm bow, with stainless steel (0,3mm I think) and use a power supply with adjustable V and A.
To cut the foam with your setup just put the wire over the foam, and increase the power; as soon as the wire starts to cut, you have your "good" point.
In my setup, this takes 2,5 A @ 12VDC, which is about 30W. You have 24V x 2A = 48W.
It depends on the wire you're using, but turn of the power as soon as the cut is done, and I think you could use more power (I would say 60-70W, for 30-45s period).
About AC and DC: there's no problem at all. For security reasons, try to connect one AC line to earth. This way you should have no problem, even if the transformed fails in service...
JP
Lisbon, PORTUGAL
JP is offline Find More Posts by JP
CNC foam cutting electronics Milton Aircraft - Electric - Airplanes (FS/W) 0 Mar 20, 2005 10:52 AM
FS: CNC foam cutting electronics tomi Aircraft - Electric - Airplanes (FS/W) 5 Nov 25, 2004 10:18 PM
Best Voltage / Amperage /AC/DC for Foam Cutting mdennis Composites Fabrication 4 Jun 17, 2004 03:51 PM
foam cutting noob question johnny_carlos Foamies (Kits) 3 Jan 22, 2003 10:46 PM
Another foam cutting question....filament... JayParke Foamies (Kits) 3 May 26, 2002 05:47 PM
