Espritmodel.com Heli Air
Old Jul 21, 2002, 01:11 PM
Joined Jul 2002
Airfoil Design Software?
Does anyone use an Airfoil Design Program when creating their projects. If so which one is the best?
Tin Pusher is offline Find More Posts by Tin Pusher
Old Jul 21, 2002, 08:22 PM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
I have used PROFILI, a free download air foil program.
Do a search here, you will find the link.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
profili is free but limmited.
http://www.aerodesign.de/
omega blood is offline Find More Posts by omega blood
Old Jul 21, 2002, 10:15 PM
Albuq, NMex USA
Joined Jan 2001
http://students.cs.tamu.edu/farzu/
This is a link to a very nice free program (Profile) that allows you to change camber, thickness and add washout. Best used by folks wanting to cut foam cores, as it will create the image of the template as well as the airfoil.
It may be the best of the free airfoil plotting programs.
MikeC is offline Find More Posts by MikeC
Old Jul 22, 2002, 12:11 AM
Joined Jul 2002
Thanks, I will give it a try.
Old Jul 22, 2002, 08:34 AM
Toledo Ohio, USA!
Joined Dec 2001
I have WingMaster 98 I am selling. Over 250 preset airfoils. and Unlimited make your own ones. Just tell it what you want, it draws it up! I really like it.
Gonflyin01 is offline Find More Posts by Gonflyin01
Old Jul 22, 2002, 12:37 PM
United States, CA
Joined Dec 2001
CompuFoil is the most popular, I believe, software for model airfoil layout, for both built-up and foam core designs. It's capability is impressive, and the demo version is free. At least try the demo before buying any other.
http://www.compufoil.com/
green66 is offline Find More Posts by green66
Old Jul 23, 2002, 04:14 PM
Dave Harding's Avatar
Brookhaven, PA
Joined Mar 2002
I like Winfoil from Malcom Hardy in Austrailia.
It does a super job of airfoil plotting, has the aerodynamic data and an airplane design wizard to help you size tails, estimate performance etc.
For about $40 it can't be beat IMHO.
Do a search on Winfoil.
Dave Harding, Brookhaven Pa.
Dave Harding is offline Find More Posts by Dave Harding
Old Nov 26, 2011, 04:48 PM
Joined Nov 2011
Hi Tim,
if you're still interested in Airfoil Design Software you might want to check this out: www.evolutiondesings.eu
Best regards
ED's Team
ED_Team is offline Find More Posts by ED_Team
Old Nov 29, 2011, 10:45 AM
G_T
Joined Apr 2009
If you are actually looking to design the airfoils, you want to use something XFOIL based. This would be XFLR5 or a version of Profili. I've used a previous version of Profili, but now use XFLR5 pretty exclusively/extensively for airfoil and wing design. If you want to play with existing airfoils rather than working from scratch, Profili is likely the better choice as it comes with an airfoil library (at least if you pay for it).
If you are looking to design foils where transonic flow becomes a serious consideration, or where supersonic or hypersonic flow is involved, then I don't know what to suggest. XFOIL based programs should handle mild transonic flow but beyond that I do not know.
Gerald
PS - If you want to get an idea of some of what can be done in XFLR5, look through any of my threads. You'll find many examples from my work.
G_T is offline Find More Posts by G_T
Old Dec 06, 2011, 12:40 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Tin Pusher, you're not really giving us much to work with. You haven't said if you want to design and "test" and airfoil shape or if it's the ribs and spar layouts you're after. Some more information would help us help you more.
BMatthews is offline Find More Posts by BMatthews
Old Dec 06, 2011, 01:15 PM
I DS slower than I build!
Cory's Avatar
Idaho Falls
Joined Jul 2006
Uhmmmm...I don't think Tin Pusher is around any more. His last RCGroups activity was Jun 29, 2004 07:21 PM.
This has got to be a record for resurrection of an ollllllld thread!
Looks like we have an advertiser looking realllllly hard to scare up business. The resurrection of this thread is ED Team's one and only post.
Cory is offline Find More Posts by Cory
Old Dec 07, 2011, 06:30 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
DOH! I got burned big time on this one! I typically check to see if threads with more than a few replies that just "appear" are old or not.
More Airfoil Design Software orectolobus Modeling Science 1 Mar 13, 2008 06:08 PM
Which Airfoil Design Software Is Easy and Inexpensive? Jimmy James The Builders Workshop 12 Oct 21, 2005 06:21 PM
Which is the better Airfoil design hoppy Parkflyers 3 Aug 28, 2003 09:43 PM
HELP me choose an airfoil design hoppy Electric Plane Talk 5 Aug 28, 2003 09:27 PM
Airfoil design>Actual cutting tenover Power Systems 4 Oct 01, 2001 09:46 PM
