Old Jul 21, 2002, 12:32 PM
Runyond is offline
Find More Posts by Runyond
Runyond's Avatar
OH
Joined Jan 2002
Yet Another Zero Build Question
Hello all,
I have done a search for this but had no luck with this specific question.
In the Fuselage Assembly Section, Step 7 instructs cutting out two 5x5 mm slots located 11 mm from the center (reference Fig. 9).
Do these serve any purpose? I have read the instructions and stared at all the parts trying to divine the purpose of these slots, but I have come up empty-handed (or is that empty-minded? ).
Any words of wisdom?
Regards,
Denny
Runyond is offline Find More Posts by Runyond
Old Jul 21, 2002, 03:19 PM
modelsjets is offline
Find More Posts by modelsjets
modelsjets's Avatar
Holts Summit, Missouri
Joined Jun 2002
Yes these slots are necessary if you are going to use the stock aileron linkage setup... They provide clearance for the aileron tork-rod assemblys...
If you used a servo out in each wing, you wouldn't need the slots... I used the stock setup with mine and it flys fine...
Don't use the glue supplied with the kit, it takes forever to set up... I used Zap-O and it works great. However, don't use a kicker with it as most kickers will harm foam...
Fly it with 8cell AAA's 720ma's, get the balance forward of the position in the plans and it'll fly great...
modelsjets is offline Find More Posts by modelsjets
yet another battery charger question. gr8johnson3 Batteries and Chargers 6 Jan 08, 2004 08:49 AM
Another Corsair Build Question-OK Two. mrebman Parkflyers 2 Sep 19, 2003 12:07 AM
Another Tantrum build question turbojoe Parkflyers 3 Aug 07, 2003 09:31 PM
Yet another 400 cobalt question... tnsfrk Electric Plane Talk 1 Nov 11, 2002 01:25 AM
Yet Another C.G Question Heather Modeling Science 3 Aug 19, 2002 10:59 PM
