Old Jun 04, 2006, 12:21 PM
Letcraft is offline
Find More Posts by Letcraft
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Peck Bostonian Pup Conversion
I had a chance to fly this rubber conversion recently and was quite impressed with the results. Peck kits are reasonalbly priced and always have quality wood. I installed the Plantraco Plug & Play Deluxe starter kit, modified the LG location and made wing attach w/ magnet. A few other obvious changes to tail surfaces but, all in all, the model is a natural for the conversion. AUW w/lipo @ 24 grams. Check it out!
Letcraft is offline Find More Posts by Letcraft
Old Jun 04, 2006, 01:27 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Very nice conversion! Nice to see planes that look like planes. What's the span? Share some video if ya got it. The last Peck kit I converted (Corbin Baby Ace) had some real lumber in it. I used only the Wing spars and nose blocks and should have replaced them too as it turned out quite nose heavy.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jun 04, 2006, 01:36 PM
Inari is offline
Find More Posts by Inari
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
That's great! I've always fancied the Peck-Polymers Prairie Bird and thought that would make a good conversion too. The pup is much more handsome, though. Good job.
Inari is offline Find More Posts by Inari
Old Jun 04, 2006, 02:19 PM
rguillot is offline
Find More Posts by rguillot
rguillot's Avatar
Brooklyn NY
Joined Feb 2004
Very refreshing. Two real planes in two days. Excellent workmanship and looks good in the air!
Robert
rguillot is offline Find More Posts by rguillot
Old Jun 04, 2006, 02:52 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Wow
That is a really nice plane. Great to see stick and tissue planes.
Is that a bostonian as in the bostonian class of models or is there a real plane named the bostonian pup?
Ether way what is the span? AUW?
Billy
billystiltner is offline Find More Posts by billystiltner
Old Jun 04, 2006, 04:42 PM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
AUW w/90 Mah lipo is 24 grams. The span is 16" and it is a rubber model for Bostonian events designed by Bob Peck. The kit is only like 6 bucks or so. I swapped out some wood also but the way it flys I really think the kit wood would have been OK. The Prairie Bird looks like a natural conversion too. Glad you like it!
Old Jun 04, 2006, 07:00 PM
mike3976 is offline
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
Very nice conversion, thats my kind of micro!
mike3976 is offline Find More Posts by mike3976
Old Jun 04, 2006, 08:19 PM
rcxrob is offline
Find More Posts by rcxrob
Joined Apr 2005
Well done. I agree with Billy, it's nice to see the stick and tissue builds. You did a wonderful job on it.
Rob
rcxrob is offline Find More Posts by rcxrob
Old Jun 06, 2006, 02:58 PM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Peck conversion Baby Ace ARF
I converted Peck's Baby Ace also some time back. This airframe came out to only 15.5 grams. Used mostly kit wood and 1/32 sheet instead of the paper cutouts, (no heavy kit tissue either!). Plan to use either my JMP or DU Rx101 in this when I get them freed up from a couple of other micros. That should put it right at an ounce AUW I recon. This again was a very nice straight forward conversion. Also, I liked the looks of no wheel pants and narrower strut fairings. I have converted the Peck Aircamper peanut also w/Plantraco and it flys every bit as good as the Pup plus, it does some wicked snaps. It's all up w/bat is 20 grams.
Old Jun 07, 2006, 08:13 AM
Joined Nov 2002
Nice planes.
In the photo it looks like you have a brushless motor popping out the sheeting on the aircamper.
Billy
Old Jun 07, 2006, 08:25 AM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Thats the Plantraco pager motor mounted partially exposed like the full scale Aircampers Model "A" Engine. (I think that was a model A?)
Old Jun 09, 2006, 07:06 AM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Flight of the Peitenpol
Kinda cool shot of the Aircamper w/Plantraco equipment in action!
Old Jun 09, 2006, 08:33 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Nice models Letcraft. Great job
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 09, 2006, 02:52 PM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
What type of drive are you using?
Looooeeee! is offline Find More Posts by Looooeeee!
Old Jun 09, 2006, 03:42 PM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Motor/gearbox sizes
The Aircamper is using the Plantraco GB03, 5.25/1 gearbox w/ 4" prop same as the Pup. The Baby Ace will have a KP00 M-20 w/2.7:1 gearbox w/4" Kasun prop w/rx101 rcvr. The 14.5" span Andreason pictured here is using a KP00 outside gearbox 4.75:1 w/M-20 motor, a 4.75" Peck prop and the DU Rx101 w/1 gram actuators.
Peck Polymer Andreason conversion CA'ed fingers Scratchbuilt Indoor and Micro Models 117 Nov 27, 2013 10:44 AM
Peck Mini Bell conversion t-turley Parkflyers 7 Jan 02, 2008 04:58 AM
Enlarged Bostonian (Pup/Prairie Bird) for S400 houdini Parkflyers 1 Dec 05, 2002 12:09 PM
