Old Jun 04, 2006, 03:11 AM
malibu.ron@verizon.net
Guest
n/a Posts
Where to buy balsa wood model planes.
I need advice on where to find balsa wood model airplanes, WWII design.
It should be the type you have to cut the fuselage pieces and wing
spars out of the marked sheets of balsa wood. Something I did 50 years
ago but a hobby I wish to return to.
Boo
Boo
Guest
n/a Posts
Re: Where to buy balsa wood model planes.
Hi,
Kits like the Veron and KeilKraft rubber-powered scale models and other flying
models are available as plans with printed wood packs from
<http://www.replikit.com/>. They don't come with strip wood so you'll need to
try your local model shop for that. Sams in the UK have a cornucopia of kits
and bits, some of which comprise plans + printed sheets + stripwood as you
want. Sams are at <http://www.samsmodels.com/> and I believe they will ship
globally.
Alternatively Guillows and other kits are still available from various sources
on the web and probably also your local model shop.
Hth, and let us know how you get on,
Boo
Geoff Sanders
Geoff Sanders
Guest
n/a Posts
The old standbys are gone, but a few still exist.
> http://www.dumasestore.com/
They'll get you started - you can go on from there.
Old Jun 04, 2006, 05:11 AM
H Davis
H Davis
Guest
n/a Posts
Ron:
Check out acsupplyco.com for some good prices on Guillows kits if that is
the kind of model you are looking for. Go to the aerospace tab and then to
Guillows.
Or you can contact me. Since I got involved in RC flying, I don't think I'm
going to have time to build most of those stick models I bought a year ago.
Had big plans to build in the winter, but found myself building RC stuff
instead.
I currently have the P-47, P-40, Stearman, Catalina PBY, and some other
stuff. I may end up keeping the Catalina just in case I feel industrious.
Harlan
<malibu.ron@verizon.net> wrote in message
news:1149382157.739984.265620@j55g2000cwa.googlegr oups.com...
Old Jun 06, 2006, 01:11 AM
Guest
n/a Posts
Harlan,
I want to buy a model from you. Write me at malibu.ron@verizon.net
H Davis wrote:
> Ron:
> Guillows.
> instead.
> Harlan
Harlan,
Old Apr 20, 2012, 02:51 PM
suhermanbalsa is offline
Find More Posts by suhermanbalsa
Joined Apr 2012
Balsa Packs
BALSA PACK I
100pcs of Balsa Sheet 1.0mm x 100mm x 915mm
100pcs of Balsa Sheet 1.5mm x 100mm x 915mm
100pcs of Balsa Sheet 2.0mm x 100mm x 915mm
100pcs of Balsa Sheet 2.5mm x 100mm x 915mm
100pcs of Balsa Sheet 3.0mm x 100mm x 915mm
100pcs of Balsa Sheet 4.0mm x 100mm x 915mm
Quantity: 600pcs
Price : US$234.00
Weight : 28 KG
BALSA PACK II
100pcs of Balsa Sheet 5.0mm x 100mm x 915mm
100pcs of Balsa Sheet 6.5mm x 100mm x 915mm
100pcs of Balsa Sheet 8.0mm x 100mm x 915mm
50pcs of Balsa Sheet 9.5mm x 100mm x 915mm
50pcs of Balsa Sheet 12.5mm x 100mm x 915mm
Quantity: 400pcs
Price : US$330.00
Weight : 51.00 KG
BALSA PACK III
100pcs of Balsa Sheet 1.0mm x 75mm x 915mm
100pcs of Balsa Sheet 1.5mm x 75mm x 915mm
100pcs of Balsa Sheet 2.0mm x 75mm x 915mm
100pcs of Balsa Sheet 2.5mm x 75mm x 915mm
100pcs of Balsa Sheet 3.0mm x 75mm x 915mm
100pcs of Balsa Sheet 4.0mm x 75mm x 915mm
Quantity: 600pcs
Price : US$175.50
Weight : 21.00 KG
BALSA PACK IV
100pcs of Balsa Sheet 5.0mm x 75mm x 915mm
100pcs of Balsa Sheet 6.5mm x 75mm x 915mm
100pcs of Balsa Sheet 8.0mm x 75mm x 915mm
50pcs of Balsa Sheet 9.5mm x 75mm x 915mm
50pcs of Balsa Sheet 12.5mm x 75mm x 915mm
Quantity: 400pcs
Price : US$247.50
Weight : 38.50 KG
BALSA PACK V
200pcs of Balsa Stick 2.5mm x 2.5mm x 915mm
200pcs of Balsa Stick 3.0mm x 3.0mm x 915mm
150pcs of Balsa Stick 4.0mm x 4.0mm x 915mm
150pcs of Balsa Stick 5.0mm x 5.0mm x 915mm
100pcs of Balsa Stick 6.5mm x 6.5mm x 915mm
100pcs of Balsa Stick 8.0mm x 8.0mm x 915mm
100pcs of Balsa Stick 9.5mm x 9.5mm x 915mm
Quantity: 900pcs
Price : US$89.00
Weight : 6.00 KG
Density : Max. 150KG/M3
More information, email suhermanbalsa@yahoo.com
suhermanbalsa is offline Find More Posts by suhermanbalsa
Old Apr 29, 2012, 12:19 AM
scraper is offline
Find More Posts by scraper
Joined Sep 2008
Dont ever buy balsa from this guy, he is a fraud and your product will never arrive
scraper is offline Find More Posts by scraper
Where to buy balsa and plywood supplies. Davey01 Slope 7 Oct 18, 2005 04:33 PM
Where to buy Balsa built warbird kit? CooHead Parkflyers 11 Mar 09, 2005 10:43 PM
Where to buy balsa for molding? soholingo Composites Fabrication 7 Jul 01, 2004 01:07 PM
Where to buy exhaust stacks for scale planes? Jeff Charlot Slope 20 Dec 02, 2003 02:39 AM
Where's the best place to buy balsa? Bill Germanson Scale Kit/Scratch Built 16 Jan 29, 2003 12:06 PM
