| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
It must be a glitch
How are you going to charge (or use) your A123's?
With the release (finially) of the DeWalt 36v battery packs, we will have A123 cells to try. It is my understanding (from somebody testing A123 cells) that they absolutely will not stand a charge greater then 3.6v per cell. As our Lithium chargers are currently set to 4.2v per cell what will you use?
It may be time to spring for a good regulated CC/CV power supply. Brad
#2 |
You could use the supplied charger. Just wire up the in pack regulation circtui to the output of the charger and make a balancing tap and just set it up like it would be in th enew state still but use plugs.
#3 |
A man with too many helicopter
I plan on using my Astro 109 – if that won’t work I have no interest in these cells.
I was under the impression that lithium cells are charged to 4.1 or 4.2 volts but the nominal operating voltage is 3.6 to 3.7 volts. |
#4 |
Texas Ranger
PowerCube charger. The LiPo function allows you to set whatever pack voltage you like.
#5 | |
It must be a glitch
The A123 chemistry is different then common Lithiun Polymer and they cannt be charged over 3.6v. Brad |
#6 |
Texas Ranger
More details on the PowerCube: http://www.lomcovak.cz/charger/powercube1.html
Available in the U.S. at http://www.yntdesign.com/ Definitely not for beginners, as the voltage for LiPo charging is set manually, e.g. if you want to charge your pack to 17.8 volts, it'll let you. The LiPo mode is just a dead simple CC/CV where you pick the C and the V. It does, however, have the best software I've seen yet - and I say that as someone who develops software for a living. The software could actualy be used with any charger (or any whattmeter, for that matter). It's even got a provision for writing a user-supplied filter (using regular expressions) to accept input from anything you like, as long as you can express the data stream in some form of current, voltage and time. Multiple dataset overlays. And user-defined functions for the graphs, e.g. want to compute the area under a curve between two points on the graph? Make your custom function, click the two points on the graph and away you go. Expensive, and definitely not for someone who wants the full auto-everything setup, but quite powerful. Makes a very nice combo with my TP-1010C and TP205/210s. I bought it with the A123s in mind well over a year ago. |
#7 |
Less lean, less mean
#8 | |
#9 |
Needs a vacation
so uhh....anyone tore a pack up yet?
#10 |
I’m really not interested in some new oddball cells that require a new oddball charger
I already own way to many chargers. I will just buy some of the new TP batteries when they come out next month RC
#11 |
If you compare the fully charged voltage of packs made with the A123 cells (assuming a real full charge voltage of 3.6 V) and LiPos, there are few that are either dead on or very close. Here is what I came up with...
Code:
A123 S# | A123 V | LiPo V | LiPo S# | Delta per Cell (V) 6S | 21.6 | 21 | 5S | 0.1 7S | 25.2 | 25.2 | 6S | 0.0 12S | 43.2 | 42 | 10S | 0.1 13S | 46.8 | 46.2 | 11S | 0.046 - John |
#12 |
John if you call 0.046 v per cell undercharged then yes.
#13 |
Builder and Flyer
I have a Hyperion EOS 7i Speed 5S25N CHARGER. It charges Li-ion at to 3.6v.
The improved new revision apparently does not. |
#14 | |
Southern Pride
American Express ,of course.
#15 |
3.6V and your going to need parallel? Hum, what will be the advantage?
| Thread Tools | |
| How do you know if your ESC's really dead? | squidbait | Power Systems | 1 | Feb 08, 2005 01:17 AM |
| What are you going to power your HL Miracle with? | nadt770 | Foamies (Kits) | 0 | Dec 03, 2004 07:30 PM |
| Question What type of connector are you using on your Lipo's? | mr_ken | Batteries and Chargers | 14 | Jan 15, 2004 02:11 AM |
| How are you at landing your Parky???? | LuckyArmpit | Parkflyers | 9 | Jun 07, 2003 01:11 PM |
| how do you tell when your motor's going bad | waagbuck | Parkflyers | 10 | Sep 23, 2002 10:21 PM |
