Old Jun 02, 2006, 11:32 AM
preston_brown is offline
Find More Posts by preston_brown
Intermediate Pilot
preston_brown's Avatar
Chapel Hill, NC
Joined Dec 2005
Question
Order of assembly for thrust bearings in ECO 8 head?
Forgive this relatively simple question, but...
I got the thrust bearing kit from CME hobbies for the ECO 8 head, but I don't have order of assembly instructions. I would assume you replace the outer radial bearing in each blade grip with this order (from inside to outside):
1. Special cup washer
2. Thrust bearing washer
3. thrust bearing race
4. thrust bearing washer
5. weird machined hex nut with hex part towards the inside, threaded extension towards the outside (blade)
BUT...if I do that, and tighten things down, then there isn't enough free play in the spindle assembly. The grips get too tight.
Am I missing something or do I have something on backwards? Anyone who has done this modification remember how it goes together? Thanks a lot.
-- Preston
preston_brown is offline Find More Posts by preston_brown
Old Jun 02, 2006, 12:36 PM
Artemetra is offline
Find More Posts by Artemetra
I broke my kerpellor.
Artemetra's Avatar
Salt Lake City
Joined Sep 2004
Sounds kinda backwards - but I'm not sure from your description. When I did mine, I remember it being dead-on perfect, when the nuts are cinched down. The end nuts go with tube inside - that is, the tubular part goes toward center, and it actually inserts into the outer thrust race and cup. I can't remember if those cups go on the outside of the outermost race - but I think that's it. Don't they have the bigger I.D. and the tubular part of the nut fits into them? If so, that's how they go.
Oh yeah, don't take out the outer bearings, just add in the parts of the kit.
Artemetra is offline Find More Posts by Artemetra
Old Jun 02, 2006, 08:25 PM
Intermediate Pilot
Chapel Hill, NC
Joined Dec 2005
OK, then it starts to make sense. I'll assemble that way. Thanks.
Wanted: Thrust bearings for Eco 8 head John Boy Aircraft - Electric - Helis (FS/W) 1 May 12, 2005 12:47 AM
Hacker Brushless motor for use in Eco 8 and Voyager E Malc C Electric Heli Talk 12 Dec 29, 2003 10:06 AM
Boca Part # for Eco thrust bearings in Al Head giheli Electric Heli Talk 1 Jun 04, 2003 02:15 PM
can you put thrust bearings in an Eco? nullman Electric Heli Talk 5 Mar 05, 2002 11:36 AM
Aveox Motors in ECO 8 ShakyHands Electric Heli Talk 4 Apr 21, 2001 02:53 AM
