Old Jul 19, 2002, 04:01 PM
dommi is offline
Find More Posts by dommi
Oxfordshire, UK.
Joined Nov 1999
FVK Mini Graphite
Hi,
Has anyone info. good or bad about FVK's Mini Graphite, electric or glider version.
Thanks, Mike.
dommi is offline Find More Posts by dommi
Old Jul 20, 2002, 06:19 AM
GordonTarling is online now
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
As mine's still in its box, about all I can tell you is that is of superb quality. I can also tell you that it is not truly a 'Mini-Graphite' in the literal sense, it is more of a hotliner than that.
Gary Retterbush, who frequents these forums, has just received his and will probably be putting his together before I do, so keep an eye open for posts from him.
GordonTarling is online now Find More Posts by GordonTarling
Old Jul 21, 2002, 04:40 AM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
I asked quite many questions on this plane too, as I wanted to get it.
I delayed this for now as when I did decide to get it, FVK told me it could take up to 2 months to get it.
I understood though, that it is a beautiful plane, which you can order with, or without, flaps (6 servos or 4 servos versions), that there is some work to do on it, but still considered ARF.
As for the motor config:
Kontronik 501, with 13x8 Prop will do fine, for all around plane, but a stronger, heavier setup would be good, if you want it to be more a hotliner type.
Like the Kontronik PowerDrive set.
I am still very tempted by it, but on hold for now.
You can get the instruction manual, in English, from Electron.
Go to the "all updates" section, then you'll see it on the 6th of June.
Patrick.
Electron: http://plawner.net/
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Jul 21, 2002, 06:34 AM
Gary Retterbush is offline
Find More Posts by Gary Retterbush
I "plant" trees (balsa)
Gary Retterbush's Avatar
Eisenschmitt, Germany
Joined Jan 2002
M-G
I have the flapped version of the M-G. Here are a couple of pictures:
Gary
Gary Retterbush is offline Find More Posts by Gary Retterbush
Old Jul 21, 2002, 06:35 AM
Joined Jan 2002
M-G
Tail: You can mount servos in tail or in fuselage.
Old Jul 21, 2002, 06:36 AM
Joined Jan 2002
M-G
Fuselage with nose cone:
Old Jul 21, 2002, 06:40 AM
Joined Jan 2002
M-G
It might be that the version I have is different than FVK's. I do know that the quality is outstanding and if it flies half as good as it looks, it will be a real "keeper"!
Gary
Old Jul 21, 2002, 06:50 AM
Joined Jan 2002
Originally posted by patrick421
(SNIP)
Patrick.
Electron: http://plawner.net/ [/B]
____________________
Those instructions are not exactly correct for what I have. I think there have been some changes made and the instructions mentioned here are not really up to date. Actually, you hardly need instructions other than suggested control throws and CG.
Gary
Old Jul 21, 2002, 12:54 PM
dommi is offline
Oxfordshire, UK.
Joined Nov 1999
Hi,
Thanks all for info on Mini Graphite, most helpful.
Regards, Mike.
Old Jul 21, 2002, 03:53 PM
Bill Franke is offline
Find More Posts by Bill Franke
Little Rock Arkansas
Joined Jan 2002
Hell-o,
I have not seen this plane. Where can I get specs? I assume Aero-Model is the distributor?
Bill Franke is offline Find More Posts by Bill Franke
Old Jul 21, 2002, 03:55 PM
flyerman is offline
Find More Posts by flyerman
Foamie Hater
Joined Jul 2001
Gary
Could you post a photo of the MG put together? And maybe one of the firewall, if it comes with one.
flyerman is offline Find More Posts by flyerman
Old Jul 21, 2002, 06:30 PM
Joined Jan 2002
M-G
Originally posted by Bill Franke
Hell-o,
Try http://www.fvk.de/Englisch/Mini%20Grphit.html
Old Jul 21, 2002, 06:34 PM
Joined Jan 2002
Re: Gary
Sure can but it will be a few hours. The firewall is in and a 37mm spinner is required.
Old Jul 22, 2002, 04:15 AM
Joined Jan 2002
more photos
Motor mount:
Old Jul 22, 2002, 04:16 AM
Joined Jan 2002
photos
top view:
Wanted Vladimir / fvk mini graphite glider fuselage Hobster Aircraft - Sailplanes (FS/W) 0 Apr 25, 2007 02:58 PM
Who has a mini graphite by FVK? Philpops High Performance 15 Aug 19, 2005 01:29 AM
For Sale: FVK Model Mini Graphite $350 Brand NEW xadmin Aircraft - Sailplanes (FS/W) 7 Apr 13, 2005 11:15 AM
F/S NIB FVK Mini Graphite with Hacker Carbon F5F FAI Motor /105Amps ESC RCFLYER0001 Aircraft - Electric - Airplanes (FS/W) 5 Aug 22, 2003 10:37 PM
