Old Jun 09, 2006, 06:47 PM
Dick Rankin is offline
Find More Posts by Dick Rankin
It Is All Fun
Dick Rankin's Avatar
Arlington, Texas
Joined Mar 2003
Originally Posted by UAVPilot
Thanks jerry
I found a video that mike did awhile back. GloStik Video
There are more videos of them flying at night that some others have ( Dick , you watching?)
Sorry Ernest, I am just now catching up with your build thread. This is some amazing stuff you are giving us. Thanks.
Here is the vid of our Halloween Night Fly '05 with you and Mike flyn your stik's
http://www.rcgroups.com/gallery/show...cat=500&page=1
Dick
Dick Rankin is offline Find More Posts by Dick Rankin
Old Jun 10, 2006, 07:48 AM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
Dick
Thanks Dick
This is my practice thread for the up coming 4Q thread. I hope I'm doing OK so far.
I need to take some quick vid of these things really flying hard, None of the vids I have so far really show there stuff. But hopefully the Pursuit video that comes at the end of this build will show off the capability's.
UAVPilot is offline Find More Posts by UAVPilot
Old Jun 10, 2006, 07:15 PM
Merkaba is offline
Find More Posts by Merkaba
Semper Fly--Pro-Bro #2095
Merkaba's Avatar
Greenville, S.C.
Joined Dec 2004
Nice build! I've never built even a lazer cut kit(but plane on it soon) or anything other than an arf but stuff like this makes me want to try it. Just wondering what you used to paint with. Nice thick color. I have an SX-3 that Im thinking about getting flying and I need to paint it up. Another thread recommended sharpies.
Merkaba is offline Find More Posts by Merkaba
Old Jun 10, 2006, 10:14 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
On my normal Foamies I use Testors spray Enamel. But on the Glo Stick Series, I have been using transparent monocoat, and spray adhesive.
On the Night Stik , I want the decals to be black , but let Light show through, so I have some window tint that i will use for the decals.
You can also print a design on Avery full sheet clear labels. Spray a coat of clear over the decal to protect it from water, then apply.
I well give a example later in the build.
I have gotten real far in the Build so far, and well be posting soon. Just need to process the pics.
Old Jun 11, 2006, 11:20 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Finishing The wing.
Since the wing wiring is finished and the wing is what we are working on , we can go ahead and finish it up. That way, when we get to the fuselage lighting and finishing , the wing will be ready.
Make sure which side is up on your wing. The wing pin hole will be on the top of the leading edge tube. If you glues the bottom wing panels on first, then you will need to punch a hole in the bottom panel to run the wires through into the Fuselage, and don't put the wire notch in the center rib.
More construction Photos,
Old Jun 11, 2006, 11:53 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Fitting the wing
Process of fitting the wing to the Fuselage.
Old Jun 11, 2006, 12:09 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Wing tips.
Wing tips can very greatly. Easiest thing to do is leave them flat , or cap it with a over sized rib. But then the tip lights don't show as well.
Punch a hole for the light to reflect around, this makes the light appear brighter from all directions, then a notch for the LED, and a slot for the wire.
Old Jun 11, 2006, 12:36 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Fuselage lighting
Back to the fuselage.
The basic fuselage can be sanded now to get rid of the access material on the bottom and the front motor mount. Just don't round the top edges of the fuselage, as the top cover well be the last to glue on and sand.
The fuselage lighting is pretty simple. I added 2 LED's to the tail on this one to make it extra bright.
Also installed some flashing white LED's in front for Pursuit mode. They are 3 to 10 volts so they don't need a resistor.
I added what I call a Breathing Bulb that changes colors automatically. But when I tested it on this one , it just didn't look right so I later removed it.
I still need to make drawing for the wiring digram for the fuselage, for this section of the post, and will edit it in later.
Photo's......................................
Old Jun 11, 2006, 01:56 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Time to get some Tail.
Tail can be kind of tricky, so build carefully.
As mentioned before, A standard style vertical and hinged rudder system can be made with flat 3mm , then punch holes and mount the LED's like on the wing tips. Works OK but is not as impressive.
Photos>>>>>>>>>>>>>>>>
Old Jun 11, 2006, 02:29 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Horizontal stabilizer construction
Pretty basic tail construction.
The leading edge reinforcement is necessary, but can be made out of 1/64 plywood strips if you don't have carbon flat rod in hand.
It can also be applied to the back edge of the horizontal if you want to round off the leading edge. But you will have to be careful of limiting your elevator travel and the leading edge will not be as ding prof.
If you don't want to use tape hinges , then your on your own, they work fine for me
Old Jun 11, 2006, 04:22 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Push rods and Control horns
I make my own control horns for no apparent reason other than I know I will always have some and can make them to suit my needs.
Regular style push rods work fine, just keep them straight. Remember, this plane will go pretty fast and we don't want control surface flutter.
To remove any slop in my push rods on the control horns, I just wick a little medium CA in the linkage and plywood, accelerate it , then break it lose before it's to dry. It may stick again later but it will just pop free and still be slop free.
Do not glue in the servo tray at this point.
I will add in a dimensional drawing of the control horn template and edit it in later.
Old Jun 11, 2006, 04:59 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Mounting the Wing
To mount the wing like mine , you will need,
1. 8-32 x 1" nylon bolt. Try a harware store first, if the hobbie shop is to far away, I have found them there.
2. 8-32 blind nut.
3. 2 pieces of 3mm depron cut 2 x 1 1/8.
4. plywood strip to cap one edge of the mount.
Old Jun 11, 2006, 05:27 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Well , That's were I'm at right now.
Can go ahead and hook up the tail light and turn every thing on.
No peaks on this one till the video
Next step well be the mounting the motor, Caping the Fuse, and then making and installing the landing Gear.
Need to do a little shop cleaning right now
Stay tuned!
Old Jun 12, 2006, 08:30 AM
It Is All Fun
Arlington, Texas
Joined Mar 2003
Once again Ernest, this is truely amazing stuff. I have always wanted to just spend some time with you to see how you produce such amazing builds.
Ho XVIII (Horten 18 Amerika Bomber) - Design/Build Thread Cyberman Electric Ducted Fan Jet Talk 59 Aug 01, 2011 07:42 PM
Discussion LD-4 Design and Build Thread Tom Harper Modeling Science 139 Dec 14, 2009 06:59 AM
Build Log Profile SU-37 Design/Build Thread Kai_Shiden Pusher Prop Jet Models 377 Nov 14, 2007 02:26 AM
MC1 microfan rc jet design/build thread 321 Electric Ducted Fan Jet Talk 14 Sep 18, 2005 03:17 PM
LD-4 design and build thread under Modelling Science Arthur P. Aerial Photography 1 Jun 27, 2005 03:01 PM
