Old Jun 02, 2006, 02:14 PM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
Here are all the foam parts needed to build with.
I like to hold the template parts down on the foam with small pieces of the blue tape.
It may help to cut the front notch in the ribs with a piece of sharpened 1/8 inch brass tubing.
The first pic with the wing panels are all 2mm foam
The next pic is all 3mm foam
The extra pieces on the bottom are all 2 ' wide and are for internal reinforcement, they can be seen it the main plan.
I have not punched holes in all the parts yet. The reason for the holes is for many things . Wiring , cooling, and light transfer.
UAVPilot is offline Find More Posts by UAVPilot
Old Jun 02, 2006, 08:36 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Fusealage construction.
Notice that I like to use cotton swabs to wipe up excess glue.
I'll let the Pictures do the talking
Old Jun 02, 2006, 09:24 PM
Jerry Combs is offline
Find More Posts by Jerry Combs
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
Looking good! I am looking forward to the rest of the build, might learn some things.
Jerry
Jerry Combs is offline Find More Posts by Jerry Combs
Old Jun 03, 2006, 12:04 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Jerry
Thanks Jerry
I'm really surprised that there are not kits on the market made out of foam with this construction technique. I have been building planes like this for as long as I can remember. My friends and I would cut out 4 or 5 planes at one time like this except they were made of balsa and were for Glo power.
Matter of fact, below the table I'm working on, is a stack of parts for some balsa planes of the same type but for 40 size glo engines. They were called Long Johns.
Seemed natural for me to make the same thing but out of depron instead.
Old Jun 03, 2006, 12:25 AM
MonkeySee is offline
Find More Posts by MonkeySee
Monkey Do
MonkeySee's Avatar
Plano, TX
Joined Apr 2004
hey, where was my notice of this thread being started? Now I'm going to have to play catch-up.
Time to get started on this one.
MonkeySee is offline Find More Posts by MonkeySee
Old Jun 03, 2006, 01:00 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Sorry Monkey, Been meaning to Email you about it, But I know you already have the templates so you came in at just the right time really
When we get to the LED part, that will take awhile, Plus I have to go to New Jersey next week for a couple days.
Old Jun 03, 2006, 01:16 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Back to building.
The bottom has been glued on. I like using Thick CA, apply it to the edge's of the fuse then stick the bottom on. Wipe up the excess with cotton swabs , then hit it with accelerator. Make sure everything is square.
This is were it is easier to make a flat bottom plane, as it's easy to just hold the plane down flat as the glue dries. With this one , it's a little harder with the rise in the middle of the fuse.
I'm going to replace the plywood with .010 Carbon sheet when your not looking Why? cause I have it
Old Jun 03, 2006, 01:36 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
If your wondering why the plywood goes in first, Its because the landing gear is held on with rubber bands. There will be to carbon rods stuck through the foam layer just above the plywood. The plywood keeps the rod from being riped through the bottom, and the foam layer on top helps to guide the rod through during the insertion process.
I noticed that the tiled plans do not have the cross shaped plywood reinforcement on the drawing. But the full size sheet does.
We will get into this later on in the build.
Old Jun 03, 2006, 07:41 AM
gsjames is offline
Find More Posts by gsjames
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
You 'otta have EAM make up some kits for sale as long as he is doing the "other" model. He has Steve Westerfeld's CNC foam cutter and I can make up the CAD files. Give him a call and see if he is interested in doing so. It might make some money for you, not that you and Mike will need it "when your ship comes in", so to speak. Or maybe Tim Hart would like to add the kit to his line up, He uses a CNC router to cut his Foamy Factory models. Steve also has a CNC router. I'm gonna have to wait until I get back from the UAV course in San Diego next week to get started, but perhaps you'll bring the GreenGlo to TCA tonight.
gsjames is offline Find More Posts by gsjames
Old Jun 03, 2006, 11:24 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
We thought about kitting them, that's why it took so long to do a build thread. Still might.
I probably will bring the GreenGlo tonight to TCA, but that's a pretty small gym for it to do much with. Can always take it outside and get some "sightings" over I20
Old Jun 03, 2006, 11:49 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Well , the fuselage is basically finished for now. The top will be the very last thing to glue on, after all the lighting and push rods are installed. The wing mounting block well be left out for know so it will be easier to setup the rest of the stuff.
Old Jun 03, 2006, 01:10 PM
Monkey Do
MonkeySee's Avatar
Plano, TX
Joined Apr 2004
What and where is TCA?
Old Jun 03, 2006, 01:37 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
You didn't know?
This is were I test fly all my "secret" stuff Everybody should come on out. You never know what you might see there. Was the first place the original flying hydros were tested
Info Here http://www.michaelconnally.com/forum/viewtopic.php?t=7
Might be kinda far for you I think?
Old Jun 03, 2006, 03:17 PM
Monkey Do
MonkeySee's Avatar
Plano, TX
Joined Apr 2004
Too far I'd say. There has to be something between D & FW that we all can fly in.
I wanna play with the big boys.
Old Jun 05, 2006, 04:48 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Wing Construction
OK. Time to build a wing
Because this wing is fully symmetrical, you will have to build a wing jig. The jig can be made out of anything straight, and will allow for the ribs to touch front ,center ,and back. Two straight sticks or some aluminum angle works well. Just tape down and make sure the two sticks are perfectly parallel.
At this stage the jig is not that critical to have, but it helps. However you well definitely need it when you put the top sheet on.
At this point , top and bottom doesn't matter. Just note the position of the wing pin slot in the center rib. The slot will be the top of the wing. But if you forget, we can make a new hole for the pin when finished.
More talking pictures.
Ho XVIII (Horten 18 Amerika Bomber) - Design/Build Thread Cyberman Electric Ducted Fan Jet Talk 59 Aug 01, 2011 07:42 PM
Discussion LD-4 Design and Build Thread Tom Harper Modeling Science 139 Dec 14, 2009 06:59 AM
Build Log Profile SU-37 Design/Build Thread Kai_Shiden Pusher Prop Jet Models 377 Nov 14, 2007 02:26 AM
MC1 microfan rc jet design/build thread 321 Electric Ducted Fan Jet Talk 14 Sep 18, 2005 03:17 PM
LD-4 design and build thread under Modelling Science Arthur P. Aerial Photography 1 Jun 27, 2005 03:01 PM
