Glostik Design and Build Thread
Hi Every one
This is going to be my first build thread so take it easy on me This airplane is a full fuse airframe with a full airfoil , giving it excellent wind handling characteristics and is very strong. Because of its light wing loading, Its very capable of extreme aerobatics. Also, if you chose to install the lighting system, it is even easier to see at night then it is during the day, promise. This build thread will be a little different in that not only will I give the set of plans for the first GloStik, I am going to show you how easy it is to design your own so you can change it up how ever you want. Then I will go through some extensive lighting setups that can be done. Even a set up that well include how to build a light set that will let you dial in any color of the spectrum you can imagine. Here's a quick vid, GloStik Video Lets get going!
This is for a 30 inch span model with a AUW of around 9 Oz's.
You can increase this size if you want real easy by just taking all my measurements and x 1.5. This will give you a 45 span model. Mike Connally did this and it worked fine. Just replace the 2mm foam with 3mm and the 3mm with 6mm. Motor can be any 1 once type CD ROM style spinning a 7/8/9 inch prop for the 30" span ----------------------------------------------------------------------- First things first.....Parts You will need, 1. Ghostline poster board..... Ghostline You can buy this at any Walmart or Pharmacy that carries school supplies. If you don't get this stuff , its going to be allot harder to design, as you well need a square. 2. 2MM Depron Foam. A few small sheets should be fine 3. 3MM Depron Foamwww.depronusa.com/ www.deprontexas.com/ . one small sheet should work 4. 2 pieces of 1/8 carbon tubing 125" .070" 1/8" 3.00 mm 7.6 gr carbon-tubes 5. 1 piece of .070 or .060 carbon rod. The .070 doesn't always fit into the tube so you well have to get the both to make sure. .060" 1/16" 1.5 mm 3.0 gr carbon-rods .070" 5/64" 1.8 mm 3.5 gr Also need one piece of flat carbon for the tail reinforcement. .020" x .120" -- mm. 2.2 gr 6. 1 piece of 1/64 x 6 x 12 three ply plywood superiorbalsa.com 7. pick up some Scotch 2 inch wide 3M blue painters tape # 2080 and some regular clear 3/4 inch tape. 9. Foam safe CA and Kicker. I like thick and medium. Don't even try it with out kicker. I don't recommend Gorilla glue since it shows up real bad with the lights and you can't really paint this one. |
Lighting!
There are lots of places to get LED's. Most of my plane take about 16. I use 30 awg wire for wiring. I like to use green and red to make things easier. I will make a wire chart later in the build so any one can just put in there LED color and I can help with the resistor and wire setup. Here are some places I get my stuff. http://www.superbrightleds.com/ http://www.fatsquid.com/store/ http://www.goldmine-elec.com/default.htm |
Here is a pic of the Ghostline package, really great stuff to design with. Only problem that I have had with it is that the grids are not consistent in there measurement. OK if your whole design is from one package, sucks if your trying to do an overlay and the lines don't line up
Also A pic of the different style airframes templates I have done. I have built about 6 different ones so far . All very in wingspan , wingtip style . Tail style, lighting, etc. I don't put these in cad or PDF as I usually have some one else do that for me. If some one wants to follow along and repost there's, mine, or anybody else's design in PDF feel free. ( Dick, You watching?) Somewere there is some night video, I will see if I can find it sometime. |
Forgot to mention that you will also need to pick up some brass tubing for punching holes for the LEDs ,wiring, and cooling.
Sizes are, 3/8 or 13/32. The 13/32 is what is used in the plan. 3/32 for the LED,s 1/8 if your going to do the ailerons the way I do, it'd kinda hard though. More on that later. |
Here is a fuse design that is the same as the green plane I call The Green Glo.
Normally on A stick type plane, the bottom of the Fuse is flat, but this one drops down a bit below the wing area. Gives a little more room in the radio area. Probably necessary if your going to try and put the battery inside the fuse. So far I have only held the battery outside the fuse with Velcro. Works real well and is easy to put were you want for different battery types. The Red line is the Datum line that everything is measured from. The front is 4 inches long , I have made one that was 1/4 inch longer in the nose area , but never narrower than two inch square in the front. Might be cool to narrow the front some more to 1 and 3/4 inch's. This one is also extended in length by one inch from the plans, from the wing back. The flat area in the back is for the horizontal and has a two inch cord. |
Here is a tail design that I'm going to use on this model.
The second pic shows a possible choice one might make, to give it that older look. The verticals on these models are full flying, meaning the whole thing moves. This lets you sandwich a LED between the two 2mm halves. You don't have to do it this way. You can make it out of flat 3mm depron, and just put a hinge line, but it won't light up the same way. If you go full flying vertical, this is why you need a carbon rod that will fit inside the 1/8 carbon tube. The axle uses it also. |
Thanks James
Got some stuff to sort out, then it's back to work on this one. For those interested, The name of the plane this go round will be called The Night Stik. It's going to look like a police plane with lights that can be changed in the air to "pursuit mode" Then I want to do a video skit if possible
| Thread Tools | |
| Ho XVIII (Horten 18 Amerika Bomber) - Design/Build Thread | Cyberman | Electric Ducted Fan Jet Talk | 59 | Aug 01, 2011 07:42 PM |
| Discussion LD-4 Design and Build Thread | Tom Harper | Modeling Science | 139 | Dec 14, 2009 06:59 AM |
| Build Log Profile SU-37 Design/Build Thread | Kai_Shiden | Pusher Prop Jet Models | 377 | Nov 14, 2007 02:26 AM |
| MC1 microfan rc jet design/build thread | 321 | Electric Ducted Fan Jet Talk | 14 | Sep 18, 2005 03:17 PM |
| LD-4 design and build thread under Modelling Science | Arthur P. | Aerial Photography | 1 | Jun 27, 2005 03:01 PM |
