Joined Nov 2003
I Smashed My 'Nutz
Alright Guys,
I had the first flight of my modified 'Nutz yesterday. I modified the design to carry the light weight Lipo battery that I am using. Took some inspiration from TaSaJaRa's splat. The root cord excluding elevons is 14.5" and the tip cord excluding elevons is 6" (per the original Zagnutz plans). The elevons I used were 1.5" constant cord. The Zagnutz plans can be found here:Zagnutz Plans and TaSaJaRa's splat plans can be found here: TaSaJaRa's Splat I made the elevons by doubling up the fan fold and sandwiching carbon fiber tape using epoxy. I used Tyvek for hinges. I thought that using carbon fiber in the elevons would stiffen it up a bit, but not so true... definitely nothing like balsa elevons. I was a bit skeptical about the elevons but it took me a while to build this thing, so I had to give it a try..... so off to the field i went.... I found a spot with over grown weeds and gave it a toss, the CG was right on. The plane did a smooth glide, so on the second toss I went WOT and it started climbing and banking to the right a bit, I gave it a little left stick and it banked abruptly to the right and took a full power dive into about 2 feet tall weeds. I was shocked... I recovered the plane, gave it another toss, plane banked right and I gave a little left stick and it again did the right hand bank and kissed the weeds. Recovered the plane and decided to go over the radio setup... to my surprise I found that I had hooked up the servos reversed... the servo that should have been in the elevator slot was in aileron slot and vice versa... I corrected and taped a couple of cracks that had been caused by the last 2 crashes.... third time is a charm... so off it went climbing out nicely but I noticed it was very pitch sensitive... I should have landed the plane and dialed in some expo in the elevator but the adrenaline rush was so immense that I kept flying but that flight was short lived I did another full throttle dive into the weeds. 4th flight ended the same way, I guess I needed someone by me to keep me insane and tell me to tame down the elevator... 4th flight was the was that caused most of the damage... I think following are the reasons for over responsiveness: 1- Not too stiff control surfaces. 2- Dumb pilot with almost no experience with flying wings 3- Deviation in design from the standard plans I figured that the hollow bluecor structure is light but can't take a lot of beating, so probably EPP would be the way to go. And now that I have got the planform right, I would like to have this built out of EPP so that it can take a bit more beating and stay alive through the learning curve... Do you guys know of someone who can make EPP wings for me if I sent them the plans? Also, what airfoil is recommended for the following characteristics? 1- Low flying speed 2- High lift 3- Low stall speed 4- Probably basic aerobatics Basically I want a wing that I can fly slow and grow with on my flying wing experience. I am definitely a beginner in the flying wing category... Here are a couple of lessons learned: 1- Dial in some expo on the elevator 2- Use balsa elevons, they'll save you time and headache at the expense of a few bucks And finally some pictures: |
AirBorne_AZ,
Sorry to see that you cracked your 'Nutz. The nice thing about Zagnutz is that you can build a new one for just a few bucks. Here's a good source for 100% EPP cores for a reasonable price. http://www.rcworks.com/shopdisplaypr...28all+sizes%29 Hermitt |
Joined May 2006
If you want a foil specifically developed for flying wings.....search for, download, and install the free foil plotting program called profili... the last two foils at the bottom of the list are zagi type wing foils. The program will print them any size you want. Cut out of thin brass shim stock with scissors for quick templates.. or shape out of aircraft ply, formica, or aluminum for longer lasting templates. Don't forget to raise the TE of the tip template 3/16 to 1/4 in. for washout.
Scott |
| Thread Tools | |
| A question about my Nutz | mikez104 | Flying Wings | 41 | Sep 23, 2004 12:17 AM |
| What's wrong with my 'Nutz? | AllenKll | Flying Wings | 6 | Aug 25, 2004 08:02 PM |
| I smashed my sub-micro prototype today! | Lynxman | Micro Helis | 10 | Aug 20, 2004 04:57 PM |
| Help! - my Nutz won't stay up...! | rtucker | Foamies (Kits) | 9 | Apr 25, 2003 08:43 PM |
| Here's my Nutz! | Tigger | Foamies (Kits) | 6 | Oct 03, 2002 08:46 PM |
