Old Jul 18, 2002, 11:35 PM
green66 is offline
Find More Posts by green66
United States, CA, Covina
Joined Dec 2001
Need CompuFoil Help
Hi all,
Need a tip/workaround for CompuFoil - How can I define a sheeted foam core having a foam leading edge?, i.e. top & bottom sheeting terminated about 1/2" from the leading edge?
green66 is offline Find More Posts by green66
Old Jul 19, 2002, 10:55 AM
DICKEYBIRD is offline
Find More Posts by DICKEYBIRD
DICKEYBIRD's Avatar
COLLIERVILLE, TN USA
Joined Jun 2000
Is this what you're talking about?
DICKEYBIRD is offline Find More Posts by DICKEYBIRD
Old Jul 19, 2002, 12:23 PM
green66 is offline
Joined Dec 2001
Yessirreee, absolutely! How'd 'ya do it?
Old Jul 19, 2002, 12:54 PM
DICKEYBIRD's Avatar
Joined Jun 2000
Hello green,
Actually I cheated I loaded an airfoil into C/Foil, added 3/32" sheeting and 1/2" leading edge, saved it out as .dxf, loaded it into TurboCAD, snapped & trimmed the lines at the front. If you don't have CAD, you could print your airfoil with normal sheeting and leading edge and then draw in your changes by hand.
Just curious, why the foam L.E......perhaps a combat plane to snag your opponent's streamer string?
HTH
Milton Dickey
Old Jul 19, 2002, 06:04 PM
green66 is offline
Joined Dec 2001
Actually I cheated . . . . you could print your airfoil . . . . then draw in your changes by hand.
Wooops! Sorry DB, can't accept that In this case, I want to define the foam coordinates in CompuFoil because the foam cutting service uses a CNC cutter (although they've probably got a workaround for things like this). Since you helped me before with a CompuFoil trick involving two sheeting thicknesses, I concluded, upon receiving this 2nd tip, that you must be the CompuFoil Ninja but, alas, you're mortal
Actually, your CAD suggestion is the key ==> With the modified profile in CAD, establish the origin, put some points along the modified contour, obtain the coordinates of those points, then enter them into the coordinate table in CompuFoil
3 reasons: 1) impact-resistance, repair-avoidance, 2) conventional L.E. contributes little strength, either bending or torsional (can just use a sub-L.E. for strength), and 3) I hate contouring leading edges! ==> profile is more accurate straight off the foam cutter anyway.
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
A-10 glitching issue...need some help!!! David Hogue Electric Ducted Fan Jet Talk 5 Aug 07, 2001 09:51 PM
charging rate (need a little help) papichulo Power Systems 3 Jun 16, 2001 12:05 AM
Bleriot III, need more help CoClimber Parkflyers 9 Jun 01, 2001 12:54 AM
need some help finishing my mini ifo. Jeremy_D Parkflyers 4 May 28, 2001 05:49 PM
