Old May 28, 2006, 02:00 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
Video
Hobby Lobby cessna skymaster 337 first flights
It was found after these first flights that the 3cell TP 2100 pack had too much of a voltage drop and that is why it does not seem to have enough power. at full throttle the pack was at 8 volts and 17amps ( just under 150 watts).
the watts were measured with some better batteries and just under 300 watts was achieved with the polyquest 20 2500mah pack. The battery tray will have to be enlarged a little to make room for this battery.
EDIT: video's removed to make room for other video's.
dogon1013 is offline Find More Posts by dogon1013
Old May 28, 2006, 08:02 PM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
PS. The plane is being flown by Ezed. I am behind the camera.
Old May 28, 2006, 08:45 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
I just flew mine today 4 times, 3 with stock battery 1 with 3s2p TP 1320 Pro Lite. I changed my prop to GWS 8060 HD to increase pitch speed and reduce Amp draw. Both battery produce around 200W full throttle and the plane take off nicely. I mostly fly partial throttle as this plane glides itself very well.
The twin motors with stock (GWS 9050 HD prop clone) props are Amp hog that draws around 25 Amp together with the stock battery. TP2100 Gen I and Gen II cannot provide 25 Amp. You need as least the Prolite version.
I find that two TP 1320 Prolite 3 cell batteries fits perfectly into the stock battery box. The only problem is that this make the plane a little tail heavy I need to add some weight in the front.
shschon is offline Find More Posts by shschon
Old May 28, 2006, 10:56 PM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
you say 3s2P 1320...do you mean 2640mah or are you using 660mah cells?
Old May 28, 2006, 11:31 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
I read this as having a 3S2P setup for a total of 2640mAH
Certainly a good idea as parallel will provide you with an "Effective" Capacity that is higher because the Under Load Voltage is higher in this type of setup and you can fly longer and with more Propeller RPMs than with the struggling 3S1P setups.
guapoman2000 is offline Find More Posts by guapoman2000
Article Hobby Lobby Cessna 337 Mixmaster Brushless RTF Twin Review dawnron1 Parkflyers 71 Jul 22, 2008 08:46 PM
Mini-Review Hobby Lobby Cessna 337 MIXMASTER review ATIS Parkflyers 74 Nov 16, 2007 02:18 PM
Sold *NIB* Hobby-lobby cessna skymaster xjwrench1969 Aircraft - Electric - Airplanes (FS/W) 0 Oct 09, 2006 08:29 PM
New Product New Hobby Lobby Cessna Skymaster Ralph_D Parkflyers 3 May 22, 2006 05:35 PM
