Old Jul 18, 2002, 09:25 PM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
ail/rud mixing help needed w/ flash 5X
I am trying to program this function in my radio. I followed the instructions in the manual and when I move the ailerons left the rudder moves left, but when I move the ailerons right the rudder stays neutral. The screen reads "nor" "on" and "-40%". When the stick is moved to the right the "nor" disapears and the numbers turn to "+0%" Do I need to program both sides of the f stick? If so I can find no mention of it in the manual.
Also when programming expo with this radio, I want a negative number to make the control less sensitive or twitchy near the centered positions correct?
Thanks again for the help and info.
Mike C is offline Find More Posts by Mike C
Old Jul 18, 2002, 09:54 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Page 19.
William A is offline Find More Posts by William A
Old Jul 18, 2002, 09:56 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Mike,
I fly JR so this is a guess at best, but the way it works on some functions with JR is you have to hold a little right or what ever, so you get the + with the 0%, then hit your button to increase the value. Try it!!
Later,
David
David Hogue is offline Find More Posts by David Hogue
Old Jul 18, 2002, 10:21 PM
Mike C is offline
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
I'll give it a try in the morning thanks guys!
BTW I have about 30 flights on the X250 so far and it is a great plane to fly. So far not a single crash (OK some landings weren't where I wanted them ) and I have not destroyed anything on the plane. to me this flies better in the wind than the Cutie. Life is good!
Old Jul 19, 2002, 07:01 AM
BNA Bob is offline
Find More Posts by BNA Bob
Nashville TN
Joined Apr 2001
Hi,
Yes, you do have to program both sides of the stick. Just push the stick slightly one way (L/R) and make your setting, then push the stick in the opposite direction and set the other side.
Servo endpoint adjustment works the same way.
Cheers,
--Bob
BNA Bob is offline Find More Posts by BNA Bob
Help! Help Needed w/ recent aquisition - Robbe ASW24 tdanisav Scale Sailplanes 4 Jan 09, 2006 10:05 AM
4 Rotor Heli Mixing help needed! EP heli freak! Coaxial Helicopters 15 Aug 20, 2005 11:19 PM
Need help setting up Flash 5x with elevons MaxxTrip Radios 5 Mar 02, 2004 01:14 PM
Need help on Hitec Flash 5X model mode selection. Mike C Radios 4 Jul 03, 2003 10:30 PM
Help please with Flash 5X SteveC Electric Plane Talk 3 Sep 16, 2001 09:35 PM
