Old May 27, 2006, 05:10 PM
MorrisM is offline
Find More Posts by MorrisM
MorrisM's Avatar
Oklahoma City
Joined May 2004
Mini-HowTo
LRK winding is easy.. Try it!
It seems some people have the idea LRK is hard to wind. I think the way I wind LRK is easy to do. Easier than ABC cdrom winding.
First I to cut the wire into 3 equal lengths. One for each phase. Do a test wind to determine the length. I cut 32 inch lengths of AWG24 gobrushless newbie wire for this Komodo stator. Next I find the center of each length of wire and mark it with a sharpie. I wind from the middle of the wire and repeat for the other half of the phase.
EDIT: To correct the semantics, this is called by some "distributed LRK" That is a 12 tooth wind with 10 or 14 magnet poles. Classic LRK is 6 of 12 tooth wind...every other tooth.
MorrisM is offline Find More Posts by MorrisM
Old May 27, 2006, 05:12 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Wind one tooth CW, the adjacent tooth CCW. Repeat on the other side and you have completed the first phase.
Old May 27, 2006, 05:14 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Do the other phases exactly the same.
Old May 27, 2006, 05:17 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
After you have completed winding, you will see all ends are exactly the same. It does not matter which is start or end.
Old May 27, 2006, 05:19 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Now for connections.
For Delta, connect adjacent pairs together. Very simple.
Old May 27, 2006, 05:22 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
For wye, tie together any 3 wires that are 120 degrees apart. The other 3 will go to the ESC.
Old May 27, 2006, 05:23 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Thats it Comments welcome
Morris
Old May 27, 2006, 05:31 PM
FRAMEDNLVS is offline
Find More Posts by FRAMEDNLVS
Joined Jun 2004
gone fishing
FRAMEDNLVS is offline Find More Posts by FRAMEDNLVS
Old May 27, 2006, 05:57 PM
Argyle is offline
Find More Posts by Argyle
Wind is the devil.
Argyle's Avatar
Joined Aug 2005
Also, isnt the above schema dLRK (12/12tooth) not LRK(6/12 tooth)?
Argyle is offline Find More Posts by Argyle
Old May 27, 2006, 06:11 PM
mohillbilly is offline
Find More Posts by mohillbilly
Yep I got another one.
mohillbilly's Avatar
Springfield, Mo.
Joined Jan 2005
What is the diffrence in the two? Will LRK provide better thrust/lower amps/higher RPM? Just wondering.
Mo.
mohillbilly is offline Find More Posts by mohillbilly
Old May 27, 2006, 06:19 PM
Argyle is offline
Wind is the devil.
Argyle's Avatar
Joined Aug 2005
Its a higher torque winding schema for 6 or 12 tooth stators. Most winds use larger wire than a similar ABC 9/12 cd-rom, which increases has lower resistance and better efficiency, as well as smoother throttle control.
More often than not, the performance increase isnt staggering, but definately measurable.
Old May 27, 2006, 07:07 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
more detail
I found a gobrushless 12 tooth stator and tried some more winding pics.
The wire is measured and cut to length. The middle is marked with a sharpie. This method starts in the middle, not on the end. The winding is symetrical. There is no start, no end, no need to keep track of anything, as long as you wind every phase the same.
Old May 27, 2006, 07:19 PM
MorrisM is offline
MorrisM's Avatar
Oklahoma City
Joined May 2004
Here is a classic Lrk. Using the wire cut to length helps here too. You need to thread the wire for the last few turns because you are filling in past the opening between the teeth.
Old May 27, 2006, 07:20 PM
Nooflyer is online now
Find More Posts by Nooflyer
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
Is there a way to determine the big difference because i have a ABC wound motor with 25 turns and was thinking of doing the lrk! how many turns would i need to turn on an lrk wind to get almost double torque of gthe 25t cd-rom motor!
Nooflyer is online now Find More Posts by Nooflyer
LRK winding confusion t-turley Power Systems 7 Jul 17, 2005 08:11 AM
LRK winding vs. 'Normal' winding??? minifly Power Systems 11 Jun 28, 2005 12:13 PM
