BOZ and CaptCB, I bought the Robbe no 1444. Here's specs I found on the web:
Robbe 1444The way I read that, I have 1 mm around my shaft for grease. If the bushings are bronze, how does one remove/replace them after cutting to length? How are thrust washers held in place? Should I ditch the bronze and just use thrust washers? I also have the red coupler at the top of this page http://harbormodels.com/site08/main_...propulsion.htm. Does the brass bit on the end of the shaft (that goes in to the u-joint) keep the shaft from slipping out of the stuffing tube? Thus no need for the little collar/grub screw arrangement? Do you all file a flat spot on the shaft to keep the grub screw from slipping around the shaft? (Model airplane shafts often have a flat spot/notch for this purpose, but the forces at work are, I believe, substantially greater.) In any case, I assume something must rest and spin against the end of the stuffing tube to keep the shaft for backing out and slipping into Davy Jone's Locker. I realize I'm asking lots of questions, and some are pretty basic, so I REALLY appreciate y'all patience. I'm reminded of when I first started flying RC, trying to figure out how to calculate power systems, watts/pound, etc.. Now I do it in my sleep. Thanks again! Matt |
You must be getting so sick of my questions. I'm just about finished swapping out all the ESC and motor connectors. Will post a photo in a bit. EDIT: Photo attached. Swapped the power leads to Anderson Power Poles and the ESC/Motor to gold bullet connectors. Do marine folks bother with this sort of thing, or is there perhaps some other standard used in wet environments? ESC programming was as snap and I now have forward and reverse control. I'll need to remember to swap the leads for breaking in the motor so I don't set the brushes backwards.
Hoffboy
Yes! this boat does not have ANY thrust washers, and, over the years the bushings have worn. This model has hundreds of hours of use, and I wish I had, put in Delrin, or Nylon, thrust washers, as the way the boat was built for super scale detail, I cannot remove the props, or shafts. They now rattle some. Every boat built since this one, has thrust washers, at both ends of the stuffing box! CB
HINT: always use thrust washers.
Two like matrials will wear faster. Brass on brass and so on. I always use nylon, delrin or stainless steel. Always put a flat were the grab screw sits. If not it will rase a burr and destroy your bushings when you remove the shaft. I do mount the coupling against the stern tube. In 60 years I have not had one come lose. For under 5 amps I use the Tamya style connectors, Over 5 I go with Power Pole (Sermos) or 4mm bullet. |
hoffboy, and all
I will get some photo's of my barges, showing the hulls, and the skegs. The weather has been beach overcast, not real good for photo's. My thoughts on dimensions are:24''L x 8"W, or 30"L x 10"W. I have one that is 39x10, with skegs. Push's good, and tows GREAT! I am not against, possibly doing one in fiberglass, but to mold in the skegs, is WAY to costly. What do you guys think? CaptCB
My build
Hello all,
As promised I am posting a few pictures about my build. Just a few pictures as the build goes on not a whole blog. Propulsion: Graupner Speed 500e 3:1 gearbox. 35mm 3blade prop. Viper Marine 15A speedcontroller. My 5 year old son likes all the other springer pictures so I am afraid I have to build a 2nd one as soon as this one is finished ![]() ![]() ![]() ![]() ![]() So an extra tx is needed. no1 speaks for itself no2 I clamped a square in to keep it all .....ok square ![]() no3 The cutoff becomes the stand inside the transportcase to protect the ship. More to come leighter John. |
| Thread Tools | |
| R/C Boats on TV | putt_13 | Dock Talk | 1 | Oct 23, 2011 12:30 PM |
| Wanted: old r/c boats | slowflyer | Boats (FS/W) | 2 | Jun 22, 2002 06:30 PM |
