http://nwrcsm.freeyellow.com/springer.PDF |
Hi joe and welcome aboard,
If you let us know what you plan to do, we might be able to give a good answer. But just guessing that you just want a bigger Springer, I would just use the same side view streched length wise and raise the top of the boat 1" higher. If you make the sides twice the height you will need alot more weight and power which means more money. Again....If we knew your purpose and how you are going to rig it......= a better answer to your needs ask away my friend jim
cape coral
Joined Oct 2009
i can't open that file. sorry i can only see out of one eye so all of my boat are big so i can see them i was flying planes but it got to be to hard even at a 110'' wing span i was thinking two 6v or 12v motors had been looking the Dumas American Beauty but i have had many dumas kits and the fit and wood is bad so that's where got the size from was that kit i know some one that's want to make one too so were just looking to push stuff a round the lake or get my gas boat when dies thank you for your time
![]() http://get.adobe.com/reader/ |
Joe,
Now all you have to do is to use two inches between stations versus one inch on page two of Mr. toes link and add 1" to each station height. Even I can do math If you have read the 6000 + post,...you will see that the regular size springer can push hundreds of pounds...maybe not at race speeds but it gets it done You ain't done yet? jim
Norwich, England
Joined Mar 2001
That will give you 8x the displacement. 60+lbs is a bit heavy for me. I am assembling bits for 1.5x size which is 27" x 12" x 6.75". This would give a displacement of around 27lbs & plenty of room for a drive system that includes twin 3.5" Korts & bow thruster. |
Sounds about right for a 1.5x Springer.. We DO need pics of the build though ![]() By the way, you can fit a bow thruster in a standard sized Springer ![]() http://www.rcgroups.com/forums/showp...postcount=1980 |
| Thread Tools | |
| R/C Boats on TV | putt_13 | Dock Talk | 1 | Oct 23, 2011 12:30 PM |
| Wanted: old r/c boats | slowflyer | Boats (FS/W) | 2 | Jun 22, 2002 06:30 PM |
