Old May 25, 2006, 08:45 AM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
Yet Another Raptor Build (YARB) F22
With 316 sq inches of wing area (not including tailerons), a BP21 with 8x6 prop, and likely a 1650 (possibly 2250) Lipo. We're looking at TOW of about 15 ounces, so about 6.9 oz/sqft wing loading.
Just painted it two days ago, and did controls testing yesterday. I included 'McDonalds straws' at the midpoint of the control arms to reduce the play.
I did have issues getting the CG where it needs to be, so I added about 12 inches or so of 14 gauge wire to extend my battery connection to the controller.
Already debating about the next vesion (better job of gluing so it'll weigh less, and to do the top first, then the bottom, so I can rewroute the wires /cables underneath so they won't be visible from above, possibly adding real ailerons, and going with a standard elevator, and possibly adding a servo to have separate aileron control, to allow me to create flaperons to slow the landings).
Sorry, pictures will be posted later today.
Nethole is offline Find More Posts by Nethole
Old May 25, 2006, 11:56 AM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
Too much flex in the elevon controls. Lunchtime's initial flight proved short due to induced roll when I gave additional up elevator. No damage to fuselage. Gluing elevons back onto the 'sticks'.
Old May 29, 2006, 09:58 AM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
Finally had a 'real flight' today. Morning hours before wind picked up.
Smooth landing, but managed to catch the right rear taileron to disconnect the horn from the carbon fibre insert. Now, carbon rod can twist slightly with enough force as it broke away from the gorilla glue. (Any suggestions for improving/replacing this control arrangement, please suggest them).
Was airborne for 6 minutes, with an old version BP21, with 8x6 prop, and an old maxamps 2250 (assume 2000mah capacity) and ended up with a voltage that suggested 30% capacity remaining.
If I did all the numbers right, that meant flight time sucked about 14 amps. Of course, if I count the warm up, then flight time was about 12-13 amps.
Still a lot, I really wonder if I could get away with a standard BP12 (not the new ones, the original BP12s ).
Pictures of the raptor<p>
Fullsize tail view
Fullsize top view
Fullsize top front view
Fullsize underside
Old May 29, 2006, 06:07 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
More flights today. I had much difficulty gaining altitude and required significant elevator input to climb. Checking again, my CG is about an 1.5 inches from the point where the main wing's span is reduced to that of the 'faux intakes' (from the picture, the CG I was using was 1.5 inches back from the forward most point where there is green and orange paint on each wings.
I'm thinking about moving the CG back about 1.5 more inches (so three inches from the forward most section of green/orange paint). Doing so will make placing the battery much easier, as I'll be able to slide it into one of the faux intakes, or maybe even have it in the faux canopy.
Build Log Another Raptor Build bikeman Slope 56 Jun 04, 2006 07:07 AM
Discussion Yet Another Raptor Build Thread A6INTRUDER Slope 22 Apr 07, 2006 09:49 PM
Cool Yet another Raptor conversion kit! Ben74 Electric Heli Talk 26 Aug 11, 2005 11:05 PM
Yet another Corona build in the works halljb Electric Heli Talk 40 Mar 29, 2004 08:53 AM
Yet Another Zero Build Question Runyond Parkflyers 1 Jul 21, 2002 02:19 PM
