Espritmodel.com Heli Air
Old May 24, 2006, 02:55 PM
CD-ROM Junkie
Art Newland's Avatar
Camas, Washington, USA
Joined Apr 2001
Waypoint retract servo
Anyone use one of these?
WAYPOINT PRECISION MICRO 16 G RETRACT SERVO METAL GEAR 110 DEGREE
info
Are they proportional?
TIA
Art Newland is offline Find More Posts by Art Newland
Old May 25, 2006, 09:06 PM
CD-ROM Junkie
Joined Apr 2001
nobody???
Old May 25, 2006, 10:55 PM
bsoder's Avatar
Mesa, AZ
Joined Aug 2004
Art, I haven't used that specific servo, but I've used other waypoints and really like them. I'd send Bob over at Allerc an email (contact info is on the site) and ask him about it.
Brian
bsoder is offline Find More Posts by bsoder
Old May 26, 2006, 06:15 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
It's funny that the ads page says 110 deg. but when you click on the link there for data they list a different degree for that servo [W-150MGR].
It doesn't look like they are proportional reading the data sheet. Like most retract servos they start moving and don't stop until they reach the end of the travel. In this case it looks like the servo travels 125 degrees each time it is instructed to move regardless of the channel on your receiver it is plugged into.
W-150MGR 125-Deg Retract, Metal-Gear
Weight : 16.2g/0.59oz
Torque : 4.8V / 3.9kg-cm / 52oz-in
Travel Angle 125 degrees
Speed : 4.8V/0.19sec/60?
Size(mm) : 26x13x26
Size(inch) : 1.16x0.51x1.02
Motor type : 3-Pole Ferrite
Gear type : Metal
GregG is offline Find More Posts by GregG
Old May 26, 2006, 09:21 AM
Finland
Joined Jul 2004
Mighty fast for a retract servo, my Hitec servo takes 4 secs to run 180*.... so it is much more scale movement than .4 secs for whole travel. SLAM BOOM BANG, as retracts slam in their slots..
Ceeray is offline Find More Posts by Ceeray
Old May 26, 2006, 12:00 PM
Let er Rip
Pilot44's Avatar
Long Island, NY
Joined Oct 2003
Have one in my Hyp 51, works fine, as Ceeray says, fast, And you cannot electronically slow it down.
Jim
Pilot44 is offline Find More Posts by Pilot44
Old May 26, 2006, 12:27 PM
CD-ROM Junkie
Joined Apr 2001
Thanks all. Sounds like it is non-proportional... which is a good thing for a retract servo.
Old May 26, 2006, 05:03 PM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
It would be neat to find a way to make it proportional. At 52 in/oz of torque that would be one monster of a lightweight servo with metal gears.
Old Jun 01, 2006, 11:30 AM
Canada, ON, Ottawa
Joined Mar 2000
Was working with one in my Acme Beech C-45 last night. Definately non-proportional.
JeffD is offline Find More Posts by JeffD
Old Jun 02, 2006, 03:25 PM
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Hyperion also makes a servo rate adjuster, but it cannot be used with a true (non-proportional) retract servo. It's actually two rate adjusters in one: two inputs, two outputs, one PCB and adjustment micropot.
BobRCnut is offline Find More Posts by BobRCnut
Old Jun 02, 2006, 10:45 PM
schaubro's Avatar
Colorado Springs, Co
I used one of these in my ultrafly P-51. I didn't like it. I mean it was a nice servo, but it was made to go endpoint to endpoint. I can adjust the endpoint on all my other servos. But this servo can not be adjusted.
If you want any of these, I have 2 Waypoint W-150mrs retract servos that I am trying to sell. One is NIB. The other is slightly used. I also have a package of extra arms for each one. I also have 2 dionysus Design servo rate reducers that I am trying to sell. Pm me if you are interested in any of these.
schaubro is offline Find More Posts by schaubro
Question Wobbly Hyperion Spitfire Retract - Waypoint 150mgr servo kov Electric Warbirds 7 Feb 24, 2007 01:17 AM
retract servo dottney Electric Plane Talk 4 Jan 22, 2003 06:50 PM
Pager motor retract servo, how to build? JonB Indoor and Micro Models 1 Apr 04, 2002 01:29 AM
Futaba S136G Retract Servo NIB fw-190 Aircraft - Electric - Airplanes (FS/W) 0 Apr 02, 2002 08:35 PM
hitec retract servo p471701 Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2001 01:30 PM
