Old May 24, 2006, 01:20 PM
Jon NFL is offline
Find More Posts by Jon NFL
Joined Jul 2005
Yippee!
It floats!
It floats! though 3 weeks ago, I nearly sank it. Testing the pumps and one of the feed tubes ruptured. About 30' out I noticed it listing to starboard and sitting low. As cool and composed as I think I am, the adrenaline kicked in and control buttons were pushed and pushed again. I finally did manage to get it back close to shore so I could step in and shut off power. Boy! this stuff is fun
After returning several pieces of electronics for various repairs, I was able to test all systems this morning before setting sail.
Everything works!!!!
LA Fireboat 2
1/32 scale, 40" long and 10 beam, powered by a pair of Graupner VSP drives, Tracker 3 radio with a Switch8, 9 months to build and too many $$
Jon NFL is offline Find More Posts by Jon NFL
Old May 24, 2006, 01:27 PM
wingnut163 is offline
Find More Posts by wingnut163
wingnut163's Avatar
Newburgh New York
Joined May 2005
D
sinking
wingnut163 is offline Find More Posts by wingnut163
Old May 24, 2006, 02:57 PM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Jon, Great build, but think, where else could you get more bang for your bucks. Nine months of enjoyment building, designing, and anticipating getting the boat on the water, etc. Now you can look forward to many years of competing or running the model. That is the rational I give my wife and it works part of the time. Again, great looking model. Get us some photos of it pouring on the water when you get things all worked out. Jerry J
jerryj98501 is offline Find More Posts by jerryj98501
Old May 24, 2006, 03:20 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I worry about that too, the urge to pump tons of water is inherent to building that boat.
Nice to see a finished version of the Fireboat.
Looks great, congratulations!
Guess I should get back to work on mine...
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old May 24, 2006, 05:14 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
That's what I like to see, all of the monitors working at once. There are so many boats that I see that will have only one monitor working. You have made that boat a work of art. Take a look at some of the fire trucks in the toy department for ideas, some of them have working ladders. Heck, put a working monitor on the end of the ladder.
green-boat is offline Find More Posts by green-boat
Old May 24, 2006, 05:34 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Awesome!!!!! Two thunbs up!!!!
Kmot is offline Find More Posts by Kmot
Old May 24, 2006, 05:48 PM
ropanach is offline
Find More Posts by ropanach
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
Great job!!!!
do the monitors work separetly ? or just all at one time.
ropanach is offline Find More Posts by ropanach
Old May 24, 2006, 05:50 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
looks sweet fill ALL voids with polystyrene packing foam the more the merrier
Ghost 2501 is offline Find More Posts by Ghost 2501
Old May 24, 2006, 09:28 PM
Jon NFL is offline
Joined Jul 2005
Thanks for the kind words and the help over the last several months.
>Umi - I first used 1/4 surgical tubing but after the rupture I changed to clear plastic I found online.
>Ropanach - the 5 monitors operate separately on 4 pumps.
>Ghost 2501 - good idea! ;o)
Old May 24, 2006, 10:36 PM
mike_victoriaBC is offline
Find More Posts by mike_victoriaBC
victoria, bc
Joined Oct 2003
Finally, we seen one in the water with pumps going! Congratulations.
What are you using for pumps and monitors?
mike_victoriaBC is offline Find More Posts by mike_victoriaBC
Old May 25, 2006, 02:40 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
nice job on the LA fireboat.
keith S is online now Find More Posts by keith S
Old May 25, 2006, 04:25 PM
victoria, bc
Joined Oct 2003
Hi Keith - reading your other post with the Mr Darby conversion - I still have to return your photos!!
The Nanuq runs - watching this to see how the best way is to build monitors and which pumps work well.
Regards, Mike
Old May 26, 2006, 10:06 AM
Jon NFL is offline
Joined Jul 2005
>Mike - the pumps are Delco windshield washer pumps from a salvage yard. More pix available at:
http://www.dollhousedesigns.com/FB2pix/FB2pix.html
The monitors I built from 3 different sizes of brass tubing, and a small plug with a hole in it for the stream. I kind of followed what Aimee outlined with the pillow mounted for looks only.
Old May 26, 2006, 10:53 AM
victoria, bc
Joined Oct 2003
Thanks for the info and web address - I remember looking at it some time ago and forgot about it. I don't think I'll go with that many pumps but will experiment. Any idea if the Robbe monitors perform well?
Old May 26, 2006, 12:50 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Mike, if you want some solid castings of the SKUM monitors, I can send you a couple solid pieces. You could then carefully drill out a channel, and then plug the ends of the drill holes to route water through it. The jewelers wax I ordered has yet to come in, and at this point, I am thinking of redesigning the mold. The next monitor mold would allow me to cast it in sevearl parts that would create the water channel once assembled. Let me know if you want one(or two).
