May 24, 2006, 12:27 PM
The 'Wack, BC, Canada
Joined Oct 2002
That's definetly NOT normal. It sounds like you got a batch of blades that didn't get run through the heat treatment process properley and that they are all still in the soft annealed state. Try getting some from a different supplier or ask that you be able to test a blade from the replacement box of blades. Try bending a blade. If it's properley hardened it'll most likely bend quite a ways and then snap at the end of the handle collet where all the pressure is (wear safety glasses! It'll fly like a bullet!) If it bends softly with little or no springy tendency then it's not hardened. Test any replacements even if it does cost you a blade to do so.
For plywood I cut the thin stuff with scissors or knife. For 1/16 and thicker I use my power scroll saw or bandsaw (I've got one of each, I'm spoiled).
