Espritmodel.com Heli Air
Old Jul 17, 2002, 04:56 PM
Israel
Joined Jun 2002
Corona - oneway bearing - mission completed.
Finished the mod a few min ago.
Costs:
Ergo flybar (4mm) as new and long main shaft. - 5$
oneway bearing Z402 from a friend in Hamburg - 8$
New spurgear - 12$
Total 25$
Had to test in (1:00 AM) in my living room...
The Corona is like flying on a pillow... the gyro is working smoother (altough I have these funny wiggles once in a while.
Great Mod.
eytan is offline Find More Posts by eytan
Old Jul 17, 2002, 06:55 PM
Baltimore, MD
Joined Jun 2002
since you mention it, ocationally i get this wiggle on my piccolo once in a while. very seldom though. but i wonder why. could it be radio glitches.
xxcysxx is offline Find More Posts by xxcysxx
Old Jul 18, 2002, 11:54 PM
Flying high since '85
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
I don't understand, how does a one way bearing effect the flight of a fixed pitch heli?
rdogg32 is offline Find More Posts by rdogg32
Old Jul 19, 2002, 08:55 AM
cyhyam's Avatar
Highland, CA, USA
Joined Jan 2001
It helps because it removes the "reverse torque". Put your FP heli on a lazy susan or a smooth surface and apply power, it will yaw to the left. When you reduce the power slightly it will yaw to the right. This right yaw will be removed with the one-way.
I designed the one-way for my CP Hornet and didn't believe that it would benifit a FP until one of my beta testers let me fly his. It made a tremendous difference. If you are only hovering then it won't be as noticable since the power changes are minor, once you start moving around and working the throttle you will really apreciate it.
cyhyam is offline Find More Posts by cyhyam
Old Jul 22, 2002, 12:51 PM
Sonic1's Avatar
Vancouver
Joined Apr 2002
Which Ergo flybar was this? 30, 46, or 60?
Thanks.
Sonic1 is offline Find More Posts by Sonic1
Old Jul 22, 2002, 01:41 PM
Israel
Joined Jun 2002
60
Old Jul 22, 2002, 01:46 PM
Sonic1's Avatar
Vancouver
Joined Apr 2002
Thanks!
Now I just need to find a bearing.
Old Jul 22, 2002, 11:55 PM
IL
Joined Jul 2002
Hey guys,
I have a bearing that "fits the LHM shaft pretty good" and is "one way." It shoud work and am sure if you call Boca they would know, very helpful people.
Diameter :8.03 mm
Height: 5.87 mm
One way needle bearing
# NSK TORR FC-4K
With just a little bit of work and patients anyone should be able to make this and many upgrades.
take care
taus
www.cuttingedgecnc.com
taus is offline Find More Posts by taus
Sold 12V starter Oneway bearing hex starting wand,con yttutty Aircraft - Fuel - Helis (FS/W) 2 Jun 06, 2005 06:53 PM
Corona oneway maingear clubmember94 Electric Heli Talk 3 Apr 23, 2003 11:03 AM
oneway bearing for the corona- Buy it here eytan Electric Heli Talk 1 Jul 27, 2002 11:59 AM
Longer main shaft for Corona oneway bearing mod eytan Electric Heli Talk 11 Jul 17, 2002 01:08 PM
Corona-oneway bearing eytan Electric Heli Talk 3 Jul 06, 2002 07:02 PM
