Old May 23, 2006, 12:28 PM
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Hacker A30-28 shaft set screw
Just got my Hacker A30-28 Brand New.
I would like to remove the 2 shaft set screws and reverse the shaft. One of the set screws was 1.5mm and came right out. The other one is larger then the 1.5mm screw I just removed. I have tried all my small allen keys both english and metric and nothing fits it tight enough I would attempt to break it free.
So are these 2 different sizes or did Hacker strip it out when they assembled the motor?
Thanks!
Tommy D
Tommy D is offline Find More Posts by Tommy D
Old May 23, 2006, 03:51 PM
AMA 148796
Where it Rains
Joined Jul 2002
I had the same problem and had to give up. Anybody successfully removed the screws from a A30?????
ken_keeler is offline Find More Posts by ken_keeler
Old May 23, 2006, 06:39 PM
AMA 148796
Where it Rains
Joined Jul 2002
anybody?????
Old May 24, 2006, 06:28 AM
United States, MI, South Lyon
Joined Aug 2004
I had to do it to mine to use the X-mount and the screw on prop adapter. It's been a few months, but I seem to recall having to use 1 metric and 1 SAE allen wrench. I believe they use loctite on them, so try to heat the screw with a soldering iron first, then use the allen that fits the best and be very gentle(and patient).
StrangeGager is offline Find More Posts by StrangeGager
Help! Hyperion Z 2213-24 Shaft Set Screw TXTATE Power Systems 8 Jan 02, 2007 08:59 PM
Discussion Is hacker A30 motor shaft replaceable? dalbert02 Power Systems 1 Oct 18, 2006 10:55 AM
Wanted Hacker A30 28 deeman Aircraft - Electric - Power Systems (FS/W) 2 Aug 19, 2006 09:00 AM
Sold Fs: Hacker A30-28 NIP AggieFlyer Aircraft - Electric - Airplanes (FS/W) 3 Sep 21, 2005 08:31 PM
Suggestion re: corona tail rotor shaft set screw lasllc Electric Heli Talk 0 Apr 26, 2004 10:49 AM
