Old May 22, 2006, 08:05 PM
aireze is offline
Find More Posts by aireze
Ocala, Florida
Joined Apr 2001
Thrust Tube for Wemotec Mini Fan
Hi all, want to put a small thrust tube on my Mini Fan 480, but only have about 4 inches to work with. I need to know how far I can choke down the thrust tube to get the most thrust. Any help appreciated. Rich
aireze is offline Find More Posts by aireze
Old May 22, 2006, 08:41 PM
NCC-1701 is offline
Find More Posts by NCC-1701
Joined Oct 2002
Rich,
Choking down the exhaust will decrease thrust, but increase efflux velocity. Wemotec recommends an exhaust diameter of 56mm for optimum thrust and efflux velocity. Although choking down to 56mm in only 4 ibches may be a bit abrupt.
You might try sending a PM to Herb or Haldor. They're both very knowledgeable in this area.
Rob
NCC-1701 is offline Find More Posts by NCC-1701
Old May 31, 2006, 06:51 AM
441 is offline
441
Find More Posts by 441
441
Hong Kong
Joined Jan 2004
If you go to www.pulserate.com and download their free software you will be able to print out a cone to suit your exact dimensions. IE 65mm from the back of the fan reducing to approx. 56mm at the end of the exhaust over a length of 4 inches in your case. I have the same WeMoTec mini fan and reduce over a length of 92mm to a 52mm outlet which gives me a large increase in Amps and exhaust velocity. A common reduction that you will hear quoted, however, is about 80% of the fan swept area. I know a 52mm outlet still works and gives me great results on a Typhoon 2W20 motor on 4S. 48A and I have measured 920g of thrust.
441 is offline Find More Posts by 441
Old May 31, 2006, 08:16 AM
WeMoTec is offline
Find More Posts by WeMoTec
Willich / Germany
Joined Nov 1998
4 inches is long enough.
If you taper down to 56 mm the efflux velocity rises, but the thrust does not go down (i.e. efficiency of fan rises as well).
If you go down further more, you start to trade in thrust for efflux velocity.
The minimum I saw was 48 mm.
This is for the original five bladed WeMoTec Mini Fan. Other 69 mm designs with less blades are more critical reg. the exhaust dia.
Oliver
WeMoTec is offline Find More Posts by WeMoTec
Old May 31, 2006, 12:07 PM
Westbender is offline
Find More Posts by Westbender
Westbender
Westbender's Avatar
West Bend, WI
Joined Nov 2005
Does the shape of the tube matter? In other words if it gradually changes from "round" at the fan to "oval" at the end, will it have any adverse effects?
Westbender is offline Find More Posts by Westbender
Old May 31, 2006, 12:23 PM
Appie is offline
Find More Posts by Appie
Appie's Avatar
The Netherlands, DR, Emmen
Joined Aug 2002
Rich,
This should do the trick!
(Tapered down to 56mm)
Made with Cone 1.3 a VERY handy program for making all kinds of Cone shaped obejects!!
Have fun,
Cheers,
Appie
Appie is offline Find More Posts by Appie
Old May 31, 2006, 03:57 PM
danj31 is offline
Find More Posts by danj31
Greenwood Indiana
Joined Jun 2004
If anyone is intersested I have this tool that I want to get rid of. It is a perfect fit for the minifan and was made on a CNC lathe. The lip on the front makes it so the thrust tube slides perfect over the fan and has a smooth transition on the inside.
danj31 is offline Find More Posts by danj31
Old May 31, 2006, 09:51 PM
drakonis is offline
Find More Posts by drakonis
AMA 743519 Team Heliproz Pilot
drakonis's Avatar
United States, WA, Granite Falls
Joined Mar 2006
uh how much?
drakonis is offline Find More Posts by drakonis
Old Jun 01, 2006, 01:12 AM
danj31 is offline
Greenwood Indiana
Joined Jun 2004
$80 plus S+H. It is 9 inches long.
Old Jun 01, 2006, 01:22 AM
pirate281 is offline
Find More Posts by pirate281
Joined Oct 2005
It's a good thing you included a picture, danj!
pirate281 is offline Find More Posts by pirate281
Old Jun 01, 2006, 01:45 AM
danj31 is offline
Greenwood Indiana
Joined Jun 2004
The aluminum tool is 9 inches long also-
Old Jun 01, 2006, 02:07 AM
Joined Oct 2005
exactly why i said it's a good thing you posted a picture, so the buyer is knows what they're buyin'
Old Jun 01, 2006, 07:55 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Optimum thrust/efflux velocity point depends on the airframe. Details please. Do you want max speed or max thrust?
Haldor is offline Find More Posts by Haldor
Rave Wemotec Mini Fan + Hacker B40-18S thrust data gfcermak Electric Ducted Fan Jet Talk 15 Feb 25, 2006 07:47 PM
Help! recommend a plane for WeMoTec mini fan 1satnaam Electric Ducted Fan Jet Talk 5 Feb 04, 2006 01:50 AM
how do you calculate thrust for WeMoTec midi fan? gensis5280 Electric Ducted Fan Jet Talk 1 Dec 30, 2004 04:35 PM
Best price for Wemotec Mini Fan Steve H. Electric Ducted Fan Jet Talk 6 Aug 04, 2001 01:43 AM
wemotec mini-fan 480 - 18 oz. thrust?? Voyager E Electric Ducted Fan Jet Talk 10 May 01, 2001 05:03 PM
