Old May 22, 2006, 02:55 PM
AndrésMtnez is offline
Find More Posts by AndrésMtnez
AndrésMtnez's Avatar
Madrid, Spain
Joined Dec 2004
How strong is the Mibo Spirit-E wing?
Hi
This model is what I´m looking for, 2m wingspan, aileron+flaps, two piece wing...
And I would like to buy a slope plane, but I barely go to any slope because I have to little time to fly and there´s no slopes near my home, so a slope airframe wouldn´t worth the buy for me. Then the slope cone of the Spirit-E is a great option.
My concern is the strenght of the wing due to the light construction of Mibo models. I have the Micro Flash and I broke the wing in a crash (not too hard), and I don´t know if the Spirit is built the same way...
Is there any other similar option?
I would prefer a foam veneered wing, I think they are the best strenght/price value and easier to repair.
I only fly sport hotlining, but I hate flying with the concern of the wing, like I did with the Micro Flash
Thanks in advance
Andres
AndrésMtnez is offline Find More Posts by AndrésMtnez
Old May 22, 2006, 05:45 PM
f5b@wannabe is offline
Find More Posts by f5b@wannabe
Joined Dec 2004
The same built as micro-flash
Do not use the wing for hotdoging
f5b@wannabe is offline Find More Posts by f5b@wannabe
Old May 22, 2006, 06:04 PM
jofo1 is offline
Find More Posts by jofo1
jofo1's Avatar
United States, CA, San Jose
Joined Nov 2003
I own a Spirit E that I run with a Neu 1506 motor on 12 GP2200's. Auw is 63oz, quite heavy for this plane I believe. The wings are pretty strong as I fly fairly aggressively and aerobatically with this model. I certainly would not recommend a terminal dive and full elevator pull out but it can be yanked about pretty well, even at this weight. If you keep it light there will be little you could not do with it. I have heard concerns over the quality of Mibo planes, but my experience has been the opposite in that regard, the model is of good quality for the price and certainly structurally sound (maybe I've just been lucky
BTW, it will tipstall when pulled hard in a pylon turn (even with snap flap).
jofo1 is offline Find More Posts by jofo1
Old May 22, 2006, 06:46 PM
CptMike is offline
Find More Posts by CptMike
Abundantly deficient.......
CptMike's Avatar
Orange County, CA
Joined May 2004
The Ion, (made in the Cheq Republic), available through Soaringusa.com, is a 2 meter, 2 piece, Obechi veneered over foam wing hotliner. Well thought of by many. Like $269 with flaps. Search Ion in this forum for much more info.
CptMike is offline Find More Posts by CptMike
Old May 22, 2006, 11:21 PM
chris country is offline
Find More Posts by chris country
Salida, CO.
I've been flying my Spirit-E with 10 cells and Neu motor since last early this year. I broke the carbon spar in a crash that was all my fault...I got distracted when someone almost landed on my head. Anyway, I replaced the carbon spar with a steel one instead and now have a lot of confidence with this wing. I have been flying aggresively with it and have yet to have a problem. It's a nice plane for the money and versatile with the nosecone.
Chris
chris country is offline Find More Posts by chris country
Old May 23, 2006, 09:59 AM
trashmanf is offline
Find More Posts by trashmanf
SCAMMERS WELCOME!!!!!!!!!
trashmanf's Avatar
Kent, WA
Joined Dec 2003
why does your spirit stall in a pylon turn? My micro flash used to "tip stall" when I yanked and banked, but it turned out that one of the v-tail control surfaces was binding a bit more than the other, and only showed up at high stresses. after fixing this I could really pull on it, I never had any problems with the wing but I was running lipos so probably fairly lightweight. I had some of the messiest "landings" ever with this plane and the wing held up great for me! In fact I'm thinking about getting another one.
trashmanf is offline Find More Posts by trashmanf
Old May 23, 2006, 11:37 AM
jofo1 is offline
jofo1's Avatar
Joined Nov 2003
I think its just a matter of the high wing loading. The control surfaces are very solid, I'm certain that is not the cause. I think it more to do with the planform and excessive elevator throw.
Old May 25, 2006, 12:38 PM
Madrid, Spain
Joined Dec 2004
I would use 10 gp2000, but I´m already thinking about purchasing some 20C lipos, probably Flight Power, so mine would be light.
About the Ion... I have never seen it like a hotliner, maybe it´s because here in Spain I´ve seen some, but the biggest prop I´ve seen was a 11x7 The weak fuse doesn´t help either...
I supose the Ion wing can´t be compared with the Bandit.
Andres
Old May 25, 2006, 10:31 PM
tdearman is offline
Find More Posts by tdearman
Joined Sep 2003
Does anyone have a picture of the flap control setup on this model (Spirit E)? It came with some nice threaded brass fittings, but it's not obvious to me how these are installed on the upper side of the flap (there is a recessed area but not enough material to hold the fitting.
tdearman is offline Find More Posts by tdearman
Old May 26, 2006, 10:19 AM
trashmanf's Avatar
Kent, WA
Joined Dec 2003
you have to drill it out. there is some great build threads on the spirit e you can search for, or go to mibo's website.
Old May 27, 2006, 11:36 AM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Why not try the new Kamelot from FVK? Looks decent, 2 piece wing, flaps, the works. Shipping from FVK is pretty cheap too.
More info here: http://www.rcgroups.com/forums/showthread.php?t=512672
(I was seriously considering it until an irresistible deal for a MiniNyx came along... )
simingx is offline Find More Posts by simingx
Old May 28, 2006, 10:53 AM
Madrid, Spain
Joined Dec 2004
Yes, it´s really really interesting. Moreover the LHS I usually go works with FVK
At the moment I´m going to repair the MicroFlash, so I have time to see what´s the opinion of the first owners.
Thanks all
Andres
Old May 28, 2006, 05:18 PM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
Hey Andrés,
Stop looking those weak mibo models and buy a serious hotliner. You won't regret!!! And if you are short on cash, then don't stop to look at the raketenwurm1 advance deal on www.strat.at at 299euros, you won't find any plane comparable.
OTOH, just keep repairing the MF. It's worth the damage!
regards,
Chets
chetosmachine is offline Find More Posts by chetosmachine
Old May 28, 2006, 08:34 PM
C-MIC is offline
Find More Posts by C-MIC
Hong Kong
Joined Apr 2003
Originally Posted by chetosmachine
Hey Andrés,
regards,
Chets
Yes, I agree.
I think IF transportation is no issue, the RW1 is a better choice if price /quality is concerned. At it is truely made for FAI Comp. and I have seen those mibo stuffs in hk slope, so fratigue to be even as a 'hotliner' imho.
And also, besides the 'original' RW2 ( comp. layout=light weight Kelvar fuse, and full carbon uhm spar system, etc+ CUSTOM MADE COLOUR SCHEME, mine is same as another F5F in BLACK with green stripes, his is with yellow stripe, coolest plane I have ever owned.) They also carry a RW2 SPORT VERSION.and a RW2 FULL CARBON, I bought the first and then the other 2 , all with top notch craftmanship. thou the latter 2 version has no opt for colour scheme, but the price is REALLY competitive amongst similar products.(Rainer of strat suggested that the sport version could be handle 10 cells and the all carbon, could take as much as you could squeezed into...16 cells ONLY with 3 sticks of batts in triangular shaped configuration.
I fly the sport as a 7 cell plane,the original as 16 cells ship and the all carbon one is still on the shelf..too many unfinished plane, too little time
David
C-MIC is offline Find More Posts by C-MIC
Old May 29, 2006, 01:40 PM
Madrid, Spain
Joined Dec 2004
Chets, nice to see you here
Thanks both, I think you´re right, for the price of the Spirit would be a better purchase. The only concern is the one piece wing. Seems like the Kamelot or RW are the best choices for the price.
But with theese I would finish buying a slope plane too..... too much airframes to buy, too little money
Thanks all for the inputs
Andres
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
How strong is the Pyranha build up wing Jet builder Electric Ducted Fan Jet Talk 18 Jul 03, 2003 02:32 PM
How strong is dandy sport wing? mitchydkid Parkflyers 8 Apr 23, 2003 09:37 AM
How strong must a wing be? tumad Modeling Science 11 Feb 01, 2003 09:02 AM
How to "Re-Cover" Wing-E Manchild Parkflyers 0 Nov 04, 2002 10:24 AM
