Old Jul 17, 2002, 10:19 AM
cincyfler is offline
Find More Posts by cincyfler
Cincinnati, Ohio
Joined May 2002
Reverse turn motor pusher prop?
Hey guys, I know I've read this information on this very bright forum before, but I have confused myself. I have a 400x with an astro cobalt 20. The master airscrew prop that comes with it has the letters facing towards the front of the plane. So I guess what I am asking is is this correct? The motor is the 803Z, which is reverse turning. I guess it would depend if the prop is a tractor or pusher prop, which I do not know. I'm guessing its a tractor prop, hence the reversing. Has anyone ran this setup with 10 cells? Thanks in advance!
cincyfler is offline Find More Posts by cincyfler
Old Jul 17, 2002, 10:53 AM
Barrett is offline
Find More Posts by Barrett
SKINNI MINI flyer
Barrett's Avatar
Pearl River, LA, USA
Joined Sep 2001
If the motor is timed for reverse rotation, then a normal (tractor) prop will work. The prop needs to be placed on the motor with the lettering facing forward (toward the front of the plane.) I was confused about this as well when I first started flying my Zagi.
Then one day i realized that no matter where the prop is located on plane it still has to move air in the same direction, towards the back of the plane. So its not the prop that you have to worry about its the direction that the motor is rotating.
Hope this helps. I know that its not the best explanation but if you dont understand ill go in to morer detail.
Barrett is offline Find More Posts by Barrett
Old Jul 17, 2002, 10:54 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Letters on the front of the prop.. front faces forward... a tractor prop mounts with the letters forward as a pusher prop.. a pusher prop does the same...
Direction of rotation of the -motor- is important..
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 17, 2002, 11:32 AM
Neil Morse is offline
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
This issue is very confusing to newbies, and the discussion comes up periodically. I'm only chiming in here to clarify one thing: be aware that the Paul Gunther prop commonly used on Wingos and Zagis actually has the lettering on the back. This makes an already confusing situation even more confusing to a lot of folks. Therefore, in the case of the Gunther prop, the lettering should be facing toward the rear of the plane whether the prop is being used in a tractor or pusher (with reversed motor) configuration. In the case all other props which have the letter on the front in the conventional way, the lettering should be facing towards the front of the plane. Whew ... that's probably about as clear as mud, but that's the best I can do.
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Jul 17, 2002, 03:23 PM
Barrett is offline
SKINNI MINI flyer
Barrett's Avatar
Joined Sep 2001
Good point Neil, forgot about that....
Old Jul 17, 2002, 04:44 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
And if you are still confused. Put it on turn on the motor if you do not have a whole bunch of air pushing out back switch the prop around and try agian. It will become very obvious as to which way the prop has to face.
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Jul 17, 2002, 04:52 PM
Cincinnati, Ohio
Joined May 2002
cool, thanks guys
Old Jul 17, 2002, 04:58 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
Easy way to remember:
Portion of prop facing forward during flight should be convex; portion of prop facing backward should be concave.
Now someone will come along with an exception.
Tony Turley
t-turley is offline Find More Posts by t-turley
Old Jan 06, 2003, 01:09 PM
thor4944 is offline
Find More Posts by thor4944
thor4944's Avatar
Joined Feb 2002
quick question
I have an astro 020..not reversed timmed....my buddy(knows a lot about motors) said all I have to do so I can use it on my zagi is put a pusher prop on it..is that true???
thor4944 is offline Find More Posts by thor4944
Old Jan 06, 2003, 06:07 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
It all depends does your astro 020 have the ESC conectedDirectly tothe back of the motor OR isthe ESC aways away from the motor.In other words is it sensorless or sensord motor? Now if it is a Sensord motor(Board directly solderd to motor)Then YES you need a pusher Prop. If it isa sensorless motor Disconect TWo of the wiresand SWITCH them one for the other AND fip your Prop around soit is facing the other way. what you have done there is made the motor run the other way. and the Prop will now Push Air instead of Pulling it.
Kush
Old Jan 06, 2003, 06:30 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
To add more wood to the fire.......
Most props are built like a wing/airfoil, that is, they have a thicker, more rounded leading edge and a thinner, more sharper trailing edge. Most even have a flat 'back side'.
If you were to cut your prop in half, between the hub and tip, like in a cross section, it is quite easy to see.
That being said, the correct rotation is when the thicker, leading edge, is the one to 'bite or cut into' the air first.
William A is offline Find More Posts by William A
Help! Folding pusher prop for 1200kv motor 3 cell Lipo methos Beginner Training Area (Aircraft-Electric) 9 Apr 10, 2007 06:48 AM
Discussion Has any one made a motor that will turn a ductaed fan and a prop. canadian_bacon VTOLs 3 Aug 28, 2006 12:16 AM
Discussion Pusher prop jet for SPEED 400 motor? lolzor Pusher Prop Jet Models 1 Aug 12, 2006 10:23 PM
Tractor prop to pusher prop--do I need to switch motor leads? daveh Beginner Training Area (Aircraft-Electric) 5 Jan 03, 2002 09:11 AM
Reverse rotation props for a reverse turn motor? Foxtrot Beginner Training Area (Aircraft-Electric) 2 Jul 29, 2001 08:04 AM
