Old May 22, 2006, 06:58 AM
Dynomike is offline
Find More Posts by Dynomike
Cincinnati
Joined Jul 2004
RiteWing Mini Demon Project - Quest for Ballistic / Clean Handling Mini Wing!
Just wanted to share a quick update on a project that Chris and I will be working on together in the near future. After working with Chris and buying a Demon from him recently and having such a good outcome, I approached Chris with an idea for a power system on a Mini Demon, to see if he wanted to build a wing for it. Here's an overview of the power system:
Motor: Razor 400
ESC: CC25
Pack: TP1320-3S Pro Lite
Prop: Graupner CAM 100X80mm
Bench testing of this setup shows 12.5 oz thrust, and 160 watts of power. If we can keep the wing AUW around 8-9 oz, the watts/lb and vertical performance should be killer, and hoping for speeds of about 100 level and 110+ in a moderate dive.
The main goal is to achieve a wing that performs and tracks as well as Chris's high-powered Demon full-size wings, without the usual nervous handling that super-fast mini wings tend to have.
More to follow from either Chris or myself as this unfolds, regardless of the outcome...
The attached file shows the bench test performance of the power system in terms of thrust vs. input current, while stepping throttle position from 0-100% in 10% increments.
Best Regards,
Mike Hoffmeister
Cincy OH
Dynomike is offline Find More Posts by Dynomike
Old May 25, 2006, 03:52 PM
Dynomike is offline
Cincinnati
Joined Jul 2004
I am planning to use one of the new Castle Berg 4l receivers in this wing. Can any of you comment on your experience with the new 4l?
Mike H.
Old May 25, 2006, 05:18 PM
wingnutt is offline
Find More Posts by wingnutt
Will work for foam
wingnutt's Avatar
United States, WI, Muskego
Joined Apr 2005
will this be a project for a product release, or will it be something that anyone can build (ie plans release including airfoil info, dimentions, etc)?
wingnutt is offline Find More Posts by wingnutt
Old May 25, 2006, 07:36 PM
Dynomike is offline
Cincinnati
Joined Jul 2004
Chris has already been selling the Mini Demon - this is an experiment to see how it does with a very high-powered motor system on it.
CK - any comments?? :-)
Old May 25, 2006, 09:13 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
We are gona try it ,and if it doesnt work we will try iy on the new 30' incher.
This will be the test on the mini to see where we hit the wall.
Ck
klique is offline Find More Posts by klique
Old May 25, 2006, 10:42 PM
AZcrashpro is offline
Find More Posts by AZcrashpro
AZcrashpro's Avatar
Mesa Falcon Fld, Arizona, United States
Joined May 2004
Mike H.
I am using a couple of them and have had no problems with them at all.
AZcrashpro is offline Find More Posts by AZcrashpro
Old May 25, 2006, 10:54 PM
Dynomike is offline
Cincinnati
Joined Jul 2004
That's great news - thanks. I just got 2 of them tonight and man, they are TINY!!
Mike H.
Old May 25, 2006, 11:33 PM
Taylor Mullin is online now
Find More Posts by Taylor Mullin
Registered Lipo Abuser
Costa Mesa, CA
Joined Sep 2005
How are you gonna stuff the 1320 in?
Taylor Mullin is online now Find More Posts by Taylor Mullin
Old May 25, 2006, 11:49 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
i have some 1500's that if layed side by side in a 3s config thay fit nice problem is i cut my bay for the 950's
If i open it for the 1500's then it balences with no lead.. Cool..
The 1350's sold be a glove fit in the nose..
PaulVi is offline Find More Posts by PaulVi
Old May 26, 2006, 08:04 AM
Dynomike is offline
Cincinnati
Joined Jul 2004
CK told me the battery bay will be cut clean through the wing in the fat section of the airfoil near the nose, and 2mm colorplast will be used to create the top and bottom walls of the battery bay. One fixed and one hinged for access.
Old Jun 04, 2006, 02:51 PM
monsoonrc is offline
Find More Posts by monsoonrc
Michigan
Joined Dec 2003
We have a couple 30" demons out right now in test. I have the 24" cut and ready for build and will be cutting a 26" also for test. Cris and myself want to have a 20MM set up that will give the Demon feel and speed in a more ecomonical package.
Larry
monsoonrc is offline Find More Posts by monsoonrc
Old Jun 04, 2006, 04:53 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Sure, now you bust out the 25" wings. I just ordered a Scrappy.
bildo baggins is offline Find More Posts by bildo baggins
Old Jun 04, 2006, 06:34 PM
klique is offline
Mum is the word!
Joined Jun 2003
cancel your order on the scrappy.
LOL
Ck
Discussion Ritewing 25' Mini demon & 32'FS AKA spanker klique Flying Wings 746 Sep 21, 2009 06:41 PM
Build Log Ritewing Mini-Demon build (22" mini-wing) chuckand Flying Wings 85 Sep 08, 2009 02:10 AM
For Sale For Sale - E-Flite Mini Ultra Stick w/6 Servos, ParkBEC, etc! ***REDUCED*** N925WB Aircraft - Electric - Airplanes (FS/W) 1 Jul 29, 2007 06:02 PM
Build Log When less is more (36" Ritewing Demon Project) chuckand Flying Wings 24 Nov 04, 2006 10:42 AM
Sold Ritewing Mini-Demon Kit (NIB) Tank52 Aircraft - Electric - Airplanes (FS/W) 6 Oct 28, 2006 02:30 PM
