Old May 22, 2006, 03:31 AM
rmasu is offline
Find More Posts by rmasu
Joined Feb 2006
how hot is too hot for esc and motor
Hi all,
I bought this cheapo motor on ebay form xmseller, seemed like a pretty good deal 30 bucks or so labeled as a 3500 kv.
I am running a CC45 with the same settings I had on my corona with a mega 16-15-3 can't quite remember the exact settings ,but using those recommended by the "gurus" on this board so I really do trust them.
I have a jet ranger shell and running an apex 15c 2200 3s lipo.
After a 5 minute hover/ flight I pulled the nose off and measured the ecs at 150 and the motor at 185. This seemed pretty hot to me, ambient was about 77 F. I dont really care if I fry this motor but can this cheapo motor be breaking my esc? When I ran the mega 16-15-3 with the same battery and esc it would get to about 180 with no body on, but I never did measure the ecs temp with the mega. I read the megas get naturally hot so it didn't really bother me. Any other cooler running motors out there? I did check my gear mesh and tail belt tension and both are not too tight.
Oh I am running an align head sink on both, and have cut some cooling holes in the bottom of the Jet ranger.
any input appreciated.
Thanks!
rmasu is offline Find More Posts by rmasu
Old May 22, 2006, 06:28 AM
swatson144 is offline
Find More Posts by swatson144
That'll hold until ...
swatson144's Avatar
Hampton Roads Va.
The motor is getting too hot, maybe lower the pinion a tooth or 2 if possible. The 16-15-3 is 3000 kv so you are probably having heat from too tall gearing.
The CC45 is comfortably warm. Cooler is better.
Steve
swatson144 is offline Find More Posts by swatson144
Old May 22, 2006, 03:33 PM
rmasu is offline
Joined Feb 2006
ok, but I'm already running the 11 tooth pinion, where do I get a smaller pinion, or any other cooler motors out there?
Thanks!
Old May 22, 2006, 04:21 PM
zx1100 is offline
Find More Posts by zx1100
zx1100's Avatar
ILLINOIS
Joined Dec 2005
I just ran my ARK with an APEX 2200, CC35, and an AON motor last night and the motor temp was around 120 +/- depending on where I point the temp gun. The battery was mid 90s and if I remember correctly my ESC was was around that temp also. I was mainly hovering trying to adjust everything after rebuilding the head.
zx1100 is offline Find More Posts by zx1100
Old May 22, 2006, 04:48 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
your temp readings on motor and ESC seem too high. The temp on my trex with JGF 450 or align 430L motor is around 110-130 (with 450TH I pointed the temp meter at the coil.) with heavy sport flying.
A bad motor could fry and could kill your ESC.
thanhTran is offline Find More Posts by thanhTran
Question How hot is too hot for a can motor? roosevelt Power Systems 7 May 21, 2006 09:33 AM
How hot is TOO hot for a bl motor? Silverstreak328 Micro Helis 16 Sep 29, 2004 08:50 PM
How hot is too hot for motor? skyhawk Electric Heli Talk 6 Aug 10, 2003 11:26 PM
Battery temperature: How hot is too hot for LMR sailplanes jshelton Power Systems 8 Nov 02, 2001 06:48 PM
How hot is too hot for a SP400 motor? Steve Fehr Electric Plane Talk 4 Oct 22, 2001 03:56 PM
