Old May 21, 2006, 04:53 PM
Starguard is offline
Find More Posts by Starguard
Going Home
Starguard's Avatar
Mighty Midwest
Joined Apr 2004
Need info on a K&B 40 size engine
Does anyone here know anything about these engines? How reliable are they and how do they hold up performancewise?
Starguard is offline Find More Posts by Starguard
Old May 21, 2006, 07:55 PM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
The 8011 was great. The 4011 was a hit and miss kind of engine. This depended on who owned K&B as it changed owners a lot. Performance wise? What do you mean? It only put out about 0.8 HP at 15k rpm. It was a very reliable sport engine. I ran mine on 15% nitro and used Top Flight 9 x 6 props.
Konrad
P,S. 8011 had a bushing for the front bearing. The 4011 had two ball bearings.
Konrad is offline Find More Posts by Konrad
Old May 22, 2006, 12:36 PM
andernamen is offline
Find More Posts by andernamen
andernamen's Avatar
United States, VA, Virginia Beach
Joined Aug 2005
I've got a 4011 and it has been very reliable. It doesn't have much compression even when new because it has a dykes ring. It was my first engine and everyone told me it was junk because it didn't have any compression. Once started and broken in, you'll get plenty of use out of it.
andernamen is offline Find More Posts by andernamen
Old May 22, 2006, 05:53 PM
Konrad is offline
Everett Wa.
Joined Jun 2001
Dyke ring are low-tension ring and rely on cylinder pressure to push them against the cylinder to make a seal. A good dykes ring should feel bad to a slow hand flip.
The problem with some K&Bs is that the crank case seals were not very good and the rods had too much bearing clearances. This had a lot to do with the (some) owners wanting to use too high a tool feed speed in a vain attempt to increase profits. Engines built when modelers ran the company instead of venture capitalists are very good.
Andernamen,
As you learned hand-cranked compression means nothing. A set in (broken in) dykes ring will still feel bad compared to a SAE D ring. But the dyke will give more power, as there is a lot less drag from the ring against the cylinder. One needs to give K&B credit for using the dyke ring. Most engine manufactures did not use the dykes ring for fear that they would loose a sale to those who would say, "it was junk see it has no compression". K&B had a well-earned reputation for strong well-mannered engines prior to the venture capitalists.
Konrad
Old May 22, 2006, 06:40 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
My 4011 will windmill in flight, power off!!!
But it does produce the proper amount of power when it's running.
Sparky Paul is offline Find More Posts by Sparky Paul
Old May 22, 2006, 06:43 PM
Going Home
Starguard's Avatar
Mighty Midwest
Joined Apr 2004
Thanks guys
Old Jun 20, 2006, 12:27 PM
APIA is offline
Find More Posts by APIA
Joined Sep 2004
In reference to post #2, Both the 8011 and 4011 have front and rear bearings, The bearings on the 8011 are smaller diameter. See the exploded view at www.mecoa.com
-Tom
APIA is offline Find More Posts by APIA
Discussion Need Info on K&B .20 engine TurboDuane Fuel Plane Talk 2 Mar 01, 2006 03:11 PM
Yippee! f/s or trade k&b .40 airplane engine nitrodude71 Aircraft - Fuel - Airplanes (FS/W) 1 Dec 31, 2004 11:57 AM
Idea Need info on Water Cooled Engine iamplanecrazy2 Dock Talk 6 Nov 01, 2004 11:55 PM
Need info on speed 400 size glider. tocano Electric Sailplanes 15 Apr 21, 2004 07:56 AM
need info on cell size vs amps vs cycle life ? epkoncept Batteries and Chargers 0 Dec 22, 2002 12:49 AM
