Old May 18, 2006, 08:11 AM
down_shift is offline
Find More Posts by down_shift
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
Question
Pulsar 2005 - F5J 400 (would an outrunner fit?)
I am considering purchasing a Pulsar 2005. Does anyone have experience with an outrunner in this plane? What outrunner and prop would be a nice combination for the 3s TP1320 prolite?
down_shift is offline Find More Posts by down_shift
Old May 18, 2006, 09:13 AM
jihlein is offline
Find More Posts by jihlein
Albuquerque, NM
Joined Aug 2002
Don't know what would be a good motor/prop combination on 3s, but for 2s, check out my Poly Pulsar outrunner installation (Hacker A20-20L, 13x8 prop):
http://www.soarabq.org/forum/viewtopic.php?t=53
I believe the poly Pulsar and Pulsar 2005 share the same fuselage.
John Ihlein
Albuquerque, NM
jihlein is offline Find More Posts by jihlein
Old May 18, 2006, 10:31 AM
bumbelbee is offline
Find More Posts by bumbelbee
Ontario, Canada
Joined Sep 2004
http://www.jutstar.com/sf/pulsarf5jinfo.htm has some info.
Also, I put a AXI 2212 in a Sky Sergio which I'm sure has the same diameter firewall. Just needed to make a "cooling hole" for the power wires.
bumbelbee is offline Find More Posts by bumbelbee
Old May 19, 2006, 03:26 PM
jiafret is offline
Find More Posts by jiafret
Tailspin
Grand Blanc, Michigan
Joined Feb 2006
I am flying a 2005 PP with a hand wound 22mm outrunner hot wind and a 4.5 Cosmotech GB and set it up the same a jihlein has. Flew it with 165 watts on a 13X11 and 3SX1500 Polyquest cells. Very nice and good vertical.
Changed to a 269 watt setup with the same motor and 3.3:1 MPX GB and it is scary fast on the climb.
I have three nose cones for the Pulsar, one sp 400, one outrunner, and one with a 300 watt Cosmotech motor and Cosmotech 4.5:1 gearbox. Only have the last one up to 250 watts on 8XGP1100's and a 11X7 CFK prop. Same performance as the outrunner and a lot more room inside.
Will soon try the 3 LiPo's on the Cosmotech at 300+ watts and hope the wings do not get ripped off. At 250+ watts I am to winch launch height in about 8 seconds. Need about half down stick to go straight up.
Weeeeeee!!!!!!!!!!!!!!!!
jiafret is offline Find More Posts by jiafret
Anybody building a Pulsar 2005? How to's would be a big help! smokinjoe Electric Sailplanes 21 Aug 14, 2005 03:04 AM
Would this body fit an aerohawk? pc_pilot Micro Helis 6 Aug 27, 2004 03:05 PM
Will an Aveox fit the MF480 without mods? Aero-BearAZ Electric Ducted Fan Jet Talk 4 Jun 04, 2001 02:56 PM
