Old Mar 02, 2012, 07:21 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Ok, been flying the Maxi 2 for the past week, what a blast! That wing really floats well !
I was going to start the build tonight on the Maxi, and just spent 2 hours reading all the threads from page 20 or so to now
on page 57, Post # 57, I see a good choice of motors to use
I'll be building my first FPV, using this wing
So far I belive I'll be using somewhere around 3S - 2x200mah lipos, and Go Pro HD, with fat Shark Goggles . I'm still learning all the FDV stuff
I have a few questions, as I went to start the build, and am all ready stuck
Whats used to glue the 2 halves together? Welders glue?
Whats a good method without making it to complexe to stiffen the elevons
I need motor/esc combo, good for FPV, carrying the Go pro etc
I also want to add LED for night flying, what do I need to do this?
Lastley, if I dont want to fly FPV, can I remove the camera and still fly it with the larger motor and same lipos, how will it ballance with camera's etc removed?
Do I need to build 2 of these, one strickley for FPV, and one for a sport/night flyer?
I really don't need a sport flyer, I just wanted a good high viz night flyer, and FPV plane
I have the Swift 2 for sport flying also have a ton of 3D airplanes I fly
Thanks for your help!
fltekdiver is offline Find More Posts by fltekdiver
Old Mar 03, 2012, 01:14 AM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
You need to keep the balance. So if yoh take the 200 grams of gopro off. You need to add weight.
For night. You need leds. And a brushed motor esc to control the on/off of the leds.
A motor with 1 kg of thrust wil be a good motor. Kva around 1000-1400
guy1a is offline Find More Posts by guy1a
Old Mar 03, 2012, 02:20 AM
Joined Jan 2010
Thanks guya1
Hows this look for the motor? I found it on page 57 , post # 852:
http://www.hobbyking.com/hobbyking/s...00Kv_550W.html
And use this for the on/off switch for the LED's ?
http://www.hobbyking.com/hobbyking/s...idProduct=8833
Old Mar 03, 2012, 02:32 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
The motor is a huge overkill ...on this maxi i use this motor
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6247
I can go 90 deg up.. 20 amps max with 10*8.4 prop
And lighter...
I can go about forever .. :-)
I use this for the leds. If you have a knob or slider you can dimm the light .. and it's less $$
http://www.hobbyking.com/hobbyking/s...idProduct=9090
Old Mar 03, 2012, 10:53 AM
Joined Jan 2010
What FPV system are you using? Is that motor enough power to pull the wing around with the FPV and equipment?
Should I build 2 of these?
One just for flying, build it light, and add LED's
The other just for FPV?
Old Mar 03, 2012, 11:57 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Tx 900/500
Vcam hk 17$
Cl osd
As i wrote. The motor pulls 90 degrees up.
If that is not power enough ....?
Old Mar 03, 2012, 01:20 PM
Joined Jan 2010
ok sounds good, I just wanted to make sure it can power everything with the load of the FPV< etc
What are you using for your FPV? I need to look into that now
I glued the wings together last night
Old Mar 03, 2012, 01:37 PM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
U never read the answers?
Old Mar 03, 2012, 05:41 PM
Joined Jan 2010
Sorry, I had to go back and re-read the last few pages, as I'm building 2-3 airplanes right now
Old Mar 05, 2012, 03:16 PM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Maxi video
5-3-2012 (2 min 31 sec)
Old Mar 05, 2012, 03:24 PM
Joined Jan 2010
Man nice video!!
I ordered my motor for the Maxi:
http://www.hobbyking.com/hobbyking/s...dProduct=14736
I also ordered 480 LED's for it!
Will post pics as I do the build!
Old Mar 05, 2012, 11:25 PM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Thank you :-)
Old Mar 07, 2012, 06:24 PM
weimer20 is offline
Find More Posts by weimer20
United States, CA, Ventura
Joined May 2010
Originally Posted by fltekdiver View Post
Man nice video!!
Looking forward to the pics!
weimer20 is offline Find More Posts by weimer20
Old Mar 07, 2012, 06:36 PM
Joined Jan 2010
It maybe alittle while, as I'm also building it for FPV flying, I'll probabley buy this to start:
http://www.readymaderc.com/store/ind...roducts_id=699
But a few of the items I want are outta stock
What size Hitec you guys using for servos? HS82mg?
I bought some 225mg for it, but I don't like them, way to heavy, so I sold them last night
Old Mar 08, 2012, 12:36 AM
rapz0r is offline
Find More Posts by rapz0r
Bipe addict.
rapz0r's Avatar
Ljubljana, Slovenia
Joined May 2007
Hey guys,
below is one of the many movies I am planing to shoot with my Maxi. This thing is so much fun!
MS Composite Maxi Swift | GoPro Onboard | Ljubljana, Slovenia | Part I (4 min 22 sec)
Hope you like it ! Feel free to comment even if you don't !
rapz0r is offline Find More Posts by rapz0r
Discussion MS Composit Maxi Swift tioli Flying Wings 7 Sep 17, 2009 05:01 PM
Discussion MS Composit Mini Swift tioli Flying Wings 19 Jun 01, 2009 09:13 PM
MS Composit SWIFT Building and flying thread! gbagley Foamies (Kits) 20 Jul 30, 2004 01:48 AM
MS Composit SWIFT Delta Wing bobf Foamies (Kits) 25 Jun 30, 2003 06:47 AM
MS Composit Swift - PAINTING? Helicool Foamies (Kits) 4 Dec 30, 2002 07:38 PM
