Old Mar 24, 2011, 06:21 PM
hawkz is offline
Find More Posts by hawkz
USA, CA, San Diego
Originally Posted by mthomas View Post
Unfortunately, Common Sense RC is the distributor in the US..
Mark
Do you mean unfortunately, CSRC is the ONLY distributor, or do you mean what you originally wrote?
hawkz is offline Find More Posts by hawkz
Old Mar 24, 2011, 06:39 PM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Hawkz... From what I understand they are the only distributor in the US, which is unfortunate in my opinion.
I'd love to hear that there is another distributor for the Swifts in the US though..
Mark
mthomas is offline Find More Posts by mthomas
Old Mar 24, 2011, 07:27 PM
hawkz is offline
USA, CA, San Diego
Man, I wish these things would go on sale. I can't cough up $120 for a plane, incl. tax & shipping.
Old Mar 27, 2011, 11:54 AM
Anthlon is offline
Find More Posts by Anthlon
Czech Republic
Joined Feb 2011
had two, great both
My friend had at first this nice piece of Dwing, i tried his one, witih motor and than without as a glider, still perfect to fly with bateries (unplugged) with in it. Than i bought one for my other friend with emax 2215motor, which is like place a jet engine on paper plane, but with reduced max of thr is great, consider weaker for great flying too. We use a 3s 2200,1800,1500 lipos with emax and Jeti ESCs 20,30A.
we had used also a Panasonic compact camera for record video, just a strapped from top, and it worked, little a redneck solution, but we did for few times.
Strongly recomend to add a carbon poles about 2mm in wings, this make plane very crashproof, without is weak to take hits.
This is video i like most, not sure if is already present here.
Youtube: Chicken or black sheep
Anthlon is offline Find More Posts by Anthlon
Old Apr 10, 2011, 03:24 AM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
there you go ...
i had my maxi wing all togather this weekend and had a good test filght & FPV flight
maxi (5 min 20 sec)
hope you like it.
guy1a is offline Find More Posts by guy1a
Old Apr 19, 2011, 04:50 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
I start with the maxi
Can you tel me if this aile/elev setup can works?
Maxi Swift test setup 1 (0 min 35 sec)
I use a Spektrum dx6i (aile & elev at 125%) with hitec HS-82MG servos
and a Dualsky XM3536CA-8 990 RPM/V
eyesonsky is offline Find More Posts by eyesonsky
Old Apr 20, 2011, 12:59 AM
Anthlon is offline
Czech Republic
Joined Feb 2011
setup
http://www.youtube.com/watch?v=ZH9ERfU5Dgs
Your setup seems to be OK, but it looks little too much of travell of elevons, you can keep this, and make other option follows, i have Dx6i too, so make it as DR Combi, and make DR with other options for aile/elev about half of your current, but as i figured, travell of end of flaping part of wing about 2cm from its straight position is enough. Start with the bigger and if it will be so much just switch to other. if it will be still to much than change both options, it depends also on servo horn hole you use. Middle one did the job. Check carefuly if your real travell of servos are same. Our first fail was that the one of them was little more than the others and the other has subtrim at different position so subtrim worked well, and the first was corrected by travell menu at Dx6i.
We also use the softest timing and softest motor reaction, and it is still good, the hard reactions could destabilise flight especialy at lower speads which are great for this plane at calm weather. (but we have probably way to much power).
Old Apr 22, 2011, 03:08 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Thanks Anthlon.
That works... just after my first crash
Maxi Swift test 1 (3 min 17 sec)
and some help from a local guy
Old Apr 30, 2011, 03:18 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Second fly... I love it
Maxi Swift test 2 (2 min 58 sec)
Ready for FPV
Old May 01, 2011, 10:39 PM
Desert Hawk is offline
Find More Posts by Desert Hawk
Arizona
Joined Aug 2006
MaxiSwift
Greetings Tamudoc04,
The MaxiSwift is a very large wing. I have had one for several years. I'm the third guy in our group to have this particular Maxi. After a number of modifications it has become a very good platform for my cameras. The Maxi does not come with wheels and because of its size and weight it's difficult to hand launch. It was only after a sturdy set of wheels was installed that the plane became fun to fly. Also I converted my Maxi to a tractor instead of a pusher.
This is just my personal observation but, because the Maxi is so large I hesitate to trasnsport it to the flying site very often. Personally I prefer the Swift II. I own five Swift II's (four are in reserve ) and it's my "go to" machine. I can't say enough good about the Swift II!
A few minutes ago I was looking at the website of Commonsenserc.com
They have the MaxiSwift, the Swift II's, and Mini Swifts for sale. I've purchase a number of Swifts from them and the company has given me excellent service.
If you wish take a look at my MaxiSwift and see how stable it flies in wind that would ground most foam planes; take a look at the clip I recently posted on Youtube.
Hope all this has not bored you, but if you're serious about getting a MaxiSwift some of the above info might be useful.
Here's the Youtube link:
MaxiSwift takes off and lands in strong wind 5-7-10.MTS (0 min 55 sec)
All the best,
Desert Hawk
Desert Hawk is offline Find More Posts by Desert Hawk
Old May 02, 2011, 08:57 AM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
First FPV
Maxi Swift FPV 1 immersion (7 min 33 sec)
Old May 07, 2011, 04:14 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I ordered my Maxi Swift from Amain this week.
Did you fellas use hot glue or CA for it?
thx
Melnic is offline Find More Posts by Melnic
Old May 07, 2011, 05:17 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
just hot glue form motor mount, wood glue for assemble wing and 3M Scotch Cross Weave Filament Reinforced Tape
Old May 07, 2011, 05:25 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Hot glue the motor mount together or hot glue the motor mount to the wing?
Old May 07, 2011, 05:36 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
both hot glue
Discussion MS Composit Maxi Swift tioli Flying Wings 7 Sep 17, 2009 05:01 PM
Discussion MS Composit Mini Swift tioli Flying Wings 19 Jun 01, 2009 09:13 PM
MS Composit SWIFT Building and flying thread! gbagley Foamies (Kits) 20 Jul 30, 2004 01:48 AM
MS Composit SWIFT Delta Wing bobf Foamies (Kits) 25 Jun 30, 2003 06:47 AM
MS Composit Swift - PAINTING? Helicool Foamies (Kits) 4 Dec 30, 2002 07:38 PM
