Old Feb 27, 2011, 04:57 AM
shaprap is offline
Find More Posts by shaprap
Videography and stuff
shaprap's Avatar
Joined Oct 2009
BKMorpheus, can you upload a picture of your maxi, with all the components in place? I'm starting to build one and I have a similar setup and a GoPro.
Also - which battery/ies are you using?
(this is kinda broken: http://www.rcgroups.com/forums/showt...9#post17242982 )
shaprap is offline Find More Posts by shaprap
Old Feb 27, 2011, 05:28 AM
BKMorpheus is offline
Find More Posts by BKMorpheus
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
okay, i will upload one later.
I fly with two LiPos in parallel. Without Video equip i use 2x 2650mah and with video equip i use 2x 2250mah or 2x 1800mah.
With 2x 2250mah + Video equip i got flight times of round about 20-30minutes.
update: picture
I changed the ESC, because the motor was stuttering at ~80% throttle (0-70% and 100% throttle were fine). Now it runs smooth from 0-100% with the new 55A Turnigy Trust ESC.
The 40A Plush ESC should be fine, i think i only got bad luck to pick a defective one.
BKMorpheus is offline Find More Posts by BKMorpheus
Old Feb 27, 2011, 06:38 AM
shaprap is offline
shaprap's Avatar
Joined Oct 2009
Awesome, Thanks!
Old Feb 27, 2011, 08:23 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Originally Posted by Fer View Post
Gary,
Thanx for the info!
This is wat i was looking at for a setup:
Motor: HK TR35-36B 1300kv
ESC: TR_S40A - TURNIGY Sentry 40amp Speed Controller (these look interesting!)
or TR_P40A - TURNIGY Plush 40amp Speed Controller
Servo's: Would either the Hitec HS-65MG or Hitec HS-82MG servo's also be sufficient enough?
Do you use a Bec for the servo's and other electronics?
Prop: Aeronout CAM-Carbon 10x7 folding prop.
RX: Hitec optima 7 2.4GHz (Aurora9), (I also have a mx12 35Mhz laying around if that would be a smarter choice to use)
Batteries: 2*Turnigy 2200mAh 3S 25C in parralel
ooh and maybe some advise about my vid TX/RX system (i will be starting with short rang flights):
TX/RX: BEV 5.8GHz 200mw (allready have this)
Osd: BEV ce-osd (allready have this)
Goggels: Fatshark base (allready have this)
All the vid gear is 12v would it be wise to use a 12v regulator? (iwould like to use a singel bat system.
Any comment would be greatly appriciated!
again thanx in advance!
Fer
Servo size requirement will depend on where they are mounted. IMO the 65 and 82 are too small for the elevon size. I started with 225's but after burning two out switched to 645's. The 225's would be large enough if you connect the elevons in a straight line from in front of the elevons but if you want them in the equipment bay the curved pushrod adds some resistance.
I don't use a BEC as my ESC is more than adequate for the on-board electronics.
Gary Evans is offline Find More Posts by Gary Evans
Old Feb 28, 2011, 02:01 PM
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
and again...
Maxi Swift FPV - short clip (2 min 50 sec)
Old Mar 04, 2011, 05:44 PM
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
Maxi Swift Crash (8 min 22 sec)
Old Mar 05, 2011, 04:27 AM
EyP3 is offline
Find More Posts by EyP3
Norbert
EyP3's Avatar
Graz, Austria
Joined Feb 2006
Very cool video, including the parts from the camera girl!
Thanks for sharing! You were lucky that the Maxi went through the tree tops down to the ground. Hopefully there was not much damage?
Norbert
EyP3 is offline Find More Posts by EyP3
Old Mar 05, 2011, 05:18 AM
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
Thanks for sharing! You were lucky that the Maxi went through the tree tops down to the ground. Hopefully there not much damage?
Norbert
Thanks!
One winglet is gone and one rudder has fissures. The motor mount is broken as well. I think this is rerpairable, but i prefer to build a new flying wing and try to build it lighter this time.
You were right about the tree tops. If i the Maxi Swift would have been much slower at that point, i'm sure it would hang in the tree tops and then i would not have any chance of getting it down. So maybe it was good that it came down that fast and hard way.
Old Mar 05, 2011, 05:51 AM
EyP3 is offline
Norbert
EyP3's Avatar
Graz, Austria
Joined Feb 2006
I would have thought that the twigs had more softened the impact. Sorry to hear, but good luck for you new build anyway! Will it be a Maxi Swift again?
N.
Old Mar 05, 2011, 07:31 AM
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
N.
This time it will be the Knurrus Maximus. It has the same wingspan, but less depth and it is a faster flying wing.
Maybe i can reach the goal to keep it under 1,5kg this time (Maxi Swift with FPV Equip = 1,75kg).
Old Mar 05, 2011, 10:58 AM
EyP3 is offline
Norbert
EyP3's Avatar
Graz, Austria
Joined Feb 2006
Nice wing also!
Where will you post your videos then?
Old Mar 05, 2011, 11:28 AM
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
Nice wing also!
Good Question. Not sure if there is a subforum on RCGroups, but i will definitely link the new videos (and build report) on fpv-community.de
Old Mar 05, 2011, 12:07 PM
EyP3 is offline
Norbert
EyP3's Avatar
Graz, Austria
Joined Feb 2006
There is a FPV forum on RCgroups, but you probably know that already.
Video Piloting (FPV/RPV)
N.
Old Mar 24, 2011, 02:50 PM
McCool is offline
Find More Posts by McCool
Canada, QC, L'Assomption
Joined Sep 2010
Where can we buy it in Canada?
looking to buy a maxi swift, but beside europe, i cannot find it anywhere, someone can give me light?
McCool is offline Find More Posts by McCool
Old Mar 24, 2011, 03:21 PM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Unfortunately, Common Sense RC is the distributor in the US..
Hope that helps,
Mark
mthomas is offline Find More Posts by mthomas
Discussion MS Composit Maxi Swift tioli Flying Wings 7 Sep 17, 2009 05:01 PM
Discussion MS Composit Mini Swift tioli Flying Wings 19 Jun 01, 2009 09:13 PM
MS Composit SWIFT Building and flying thread! gbagley Foamies (Kits) 20 Jul 30, 2004 01:48 AM
MS Composit SWIFT Delta Wing bobf Foamies (Kits) 25 Jun 30, 2003 06:47 AM
MS Composit Swift - PAINTING? Helicool Foamies (Kits) 4 Dec 30, 2002 07:38 PM
