Old May 17, 2006, 02:36 PM
kenmalecki is offline
Find More Posts by kenmalecki
Kings Park, New York
Joined Jan 2005
Best Handheld IR Temp Gauge?
I'd like to get a handheld (non-contact) temp gauge (primarily to measure the temp of motors after flight). What's the best value gauge out there? Cheapo would be OK if it works, but I don't mind spending a lot if it's for one that is significantly better than the cheapos.
Thanks!
Ken
kenmalecki is offline Find More Posts by kenmalecki
Old May 17, 2006, 03:28 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'm happy with the one I got from RadioShack, on sale for $30..
I wouldn't pay the regular $50 price, though.. wait for it to go on sale again..
..a
Old May 17, 2006, 03:36 PM
mattweisz is offline
Find More Posts by mattweisz
Cedar Rapids, IA
Joined May 2003
I use the DuraTrax FlashPoint Infrared Temperature Gauge. Currently $22.99 at towerhobbies. Works great for checking motor/battery temp.
http://www2.towerhobbies.com/cgi-bin...&I=LXEMG5&P=ML
mattweisz is offline Find More Posts by mattweisz
Old May 17, 2006, 04:16 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
From what I have seen they all work very well. If you pay more than $35 you are paying too much.
RC Man is online now Find More Posts by RC Man
Old May 17, 2006, 04:45 PM
Joined Jan 2005
Thanks! I'll get one of the cheapos and forget about the one that looks like a Star Trek phasor for $150 (I don't know the manufacturer).
Old May 17, 2006, 04:54 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
I got one from Tower also. Great little toy.
Bmr4life is offline Find More Posts by Bmr4life
Old May 17, 2006, 06:18 PM
GoBucks is offline
Find More Posts by GoBucks
United States, OH, Westerville
Joined Oct 2005
I have the Duratrax also and it works pretty well. The phaser looking one is probably the Raytek. It's more precise and focused and has a cool laser to tell you where it's measuring the temp. I've seen it for about $80 at some of the online heli shops.
GoBucks is offline Find More Posts by GoBucks
Old May 17, 2006, 07:31 PM
lawd is offline
Find More Posts by lawd
Ottawa, Ontario
Joined Oct 2005
Nothing wrong with the Duratrax from what I can see. I compared it to a more expensive fluke at work and found the results almost identical (within 0.2 degrees on room temperature surfaces).
The big thing that you are paying for in higher end units is the distance/spot ratio - where it is 1:1 in the duratrax - i.e. a 1" circle at 1" distance, the better units have more like a 8:1 thru a 50:1 spot ratio - i.e. 1/50" spot at 1". (hence the need for a laser to pinpoint)
Unless you are trying to measure temps while the heli is spinning, the cheapo will likely do fine for you
lawd is offline Find More Posts by lawd
Old May 17, 2006, 10:13 PM
Joined Jan 2005
Thanks again all!
What temp do you look for in the motor after a flight? I've heard that micros should be 120 to 140 degrees F. Minis (including Trex) should be more towards 110 degrees F. And larger birds should be at around 100 degrees F.
Old May 18, 2006, 03:18 AM
aragon is offline
Find More Posts by aragon
Cape Town, South Africa
Joined Jan 2005
Depends on the motor. Some motors run hotter than others and have different heat tolerances.
aragon is offline Find More Posts by aragon
Sold Microtemp temp gauge like new JeffShort2000 Aircraft - General - Miscellaneous (FS/W) 2 Oct 28, 2005 07:18 PM
Temp Gauge Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 2 Jan 20, 2005 06:55 PM
FS motors,esc,IR temp Sunspot Aircraft - Electric - Airplanes (FS/W) 1 Sep 28, 2004 12:32 PM
Raytec IR temp gun DavidN Electric Plane Talk 2 Jul 19, 2003 12:38 AM
IR Temp. Gauge Rob Honeycutt Electric Plane Talk 8 Feb 10, 2003 09:13 PM
