Old May 17, 2006, 04:38 AM
delamar is offline
Find More Posts by delamar
delamar's Avatar
Adelaide, Australia
Joined Apr 2006
Help!
Just about to give up on helis. please fix my uncontrolable tail wag
Ive just installed separates into a night ranger 3d, here are my parts
night ranger 3d
gws 6ch rx
jr 8310 tx
15amp esc for main
8amp esc for tail
align/telebee/zoom HH gyro
My problem is, no matter what i do, the tail wags so bad that its uncontrolable. Its like there is no esc on the tail at all, either full on or full off, causing huge over corrections. I have the gyro in HH mode, because i figure thats easier to setup. I have tried to understand the rate mode and programing revo mix, but i couldnt work that out. So im just trying to get HH mode working first, so that i can fly this thing and not give up. Ive tried adjusting the gain on the gyro, if i go below 50% the tail motor just switches off to any rudder command, but if i go over 50% i get the huge tail wag over corrections.
I have the gyro mounted vertical with the stick facing forward, as i was told. Ive tried adjusting the travel adjustments in the TX with no difference.
Ive tried trim
the heli just goes back and forth back and forth on the floor.
If i give the tail motor a small amount of rudder, it does only spin the motor slowly, rising smoothly as i input more rudder. So i figure the ESC is doing its job.
Please help, i feel like ending the heli hobby dream.
delamar is offline Find More Posts by delamar
Old May 17, 2006, 06:30 AM
sao_bilious is offline
Find More Posts by sao_bilious
Smoke me a Kipper
sao_bilious's Avatar
UK, Beds
Joined Jan 2003
More info, what make is the Esc on the tail?
sao_bilious is offline Find More Posts by sao_bilious
Old May 17, 2006, 06:48 AM
Rosella is offline
Find More Posts by Rosella
Rosella's Avatar
Adelaide, South Australia
Joined Mar 2004
I've seen those Night Rangers fly quite well so I won't pick on it yet, as I am not a fan of motored tails. But the best combination I have seen is a Castle Creations 10 amp ESC (with hard brake and fast start) and 401 for the tail. I have tried the Align/Zoom gyro and found it to slow for my belt drive micro. I prefer a GWS PG03 or go all the way and get a 401.
Have you flown at any of the indoor events in Adelaide? A few guys there might be able to sort it out. There is an idoor night tomorrow at 8.30pm, ETSA Park.
Rosella is offline Find More Posts by Rosella
Old May 17, 2006, 06:52 AM
delamar is offline
delamar's Avatar
Adelaide, Australia
Joined Apr 2006
I fly at the hub on sundays.
My night ranger 3d did fly ok with the original 4 in 1, but the 4 in 1 developed problems, so i went separates.
the ESC for main and tail is Blue arrow. cheap i know...
Old May 17, 2006, 07:16 AM
Rosella is offline
Rosella's Avatar
Joined Mar 2004
Been trying to get there myself but the other side of town for me. Anyway reaction time and steps of an ESC seem to lack on cheapies, and put them on a slow gyro, problem gets worse. Only way to see is a process of elim. So change the ESC, if still no good, the gyro.(even borrow a PG03 if possible an change that first)
Old May 17, 2006, 10:13 AM
uabass is offline
Find More Posts by uabass
Joined Mar 2004
Be sure you have initialized the tail ESC (a very common oversight when switching to separates). Usually by moving the rudder stick all the way to the left. Sometimes it only appears that the tail ESC is doing its job when it is only the gyro that is sending the signal to the tail motor and not your TX rudder stick. Also disconnect the main motor and hold down the heli, then try the tail motor without the gyro to see if the tail ESC is working.
uabass is offline Find More Posts by uabass
Old May 17, 2006, 10:59 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
I don't know how much you did for set up, but I thought I would add that you should set the heli up in standard mode first, get the tail in line....then switch to HH if you want. HH will give the tail all sorts of bad info if it is not set up straight first. I use a swivel stand (like a lazy susan) for my nitro cars, and strap the heli down to it and get it to stay straight with minimal gyro gain, after that, the gyro isn't fighting any mechanical settings in order to do it's job. Also, as I understand it, you should not use revo mix with HH. I read that on the King instructions, so I don't know how accurate it is. But it makes sense that the less you have going on programming wise, the easier it will be to set up and find probs. Hope this helps...M
PS...As always, unplug and replug batt between settings to initialize gyro.
Michael Paxton is offline Find More Posts by Michael Paxton
Old May 17, 2006, 12:25 PM
patrick181 is offline
Find More Posts by patrick181
patrick181's Avatar
USA, MO, St Charles
Joined Nov 2005
Is that the PP-8A esc you are using?
patrick181 is offline Find More Posts by patrick181
Old May 17, 2006, 01:08 PM
Mini-Dub is offline
Find More Posts by Mini-Dub
Mini-Dub's Avatar
Seattle, WA
Joined May 2006
You said "the heli just goes back and forth on the floor", so is your tail wag before you've even taken off? I believe the tail is supposed to get more locked in at a higher main rotor speed, so maybe try lifting it off real quick and see if it settles down? Just a thought.
Mini-Dub is offline Find More Posts by Mini-Dub
Old May 17, 2006, 01:31 PM
sgtmunger is offline
Find More Posts by sgtmunger
Southern California
Joined Feb 2003
Had the same problem on my Shogun V2 using the EF HH gyro and it turned out to be the reversing DIP switch on the gyro. It still controlled the same direction (thats why I didnt suspect it) but it needs to match the TX.
sgtmunger is offline Find More Posts by sgtmunger
Old May 17, 2006, 05:49 PM
delamar is offline
delamar's Avatar
Adelaide, Australia
Joined Apr 2006
Can someone explain how to set up the gyro in rate mode? Do i use revo mix? Im in the dark.
Old May 17, 2006, 05:50 PM
delamar is offline
delamar's Avatar
Adelaide, Australia
Joined Apr 2006
Yes its a BA-PP-08 Blue Arrow
Old May 18, 2006, 06:02 AM
Rob1953 is offline
Find More Posts by Rob1953
Rochester, Great Britain (UK)
I use the blue arrow pp-3c on my tail motor so the esc should be ok.
Is this your gyro?
This is why I said before use a servo to get used to the way the gyro works this way you can tell when you are in HH because the centre point will creep.
Rob
Rob1953 is offline Find More Posts by Rob1953
Old May 18, 2006, 03:29 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
you have to use a speed control with very simple software/setup to work with the heading hold gyro. if you use a speed control that has auto calibrating...you will fight it and it will never work. you need to make sure the speed control you are using will not adjust itself to the throttle travel.the one I have used with success is the GWS 2 amp unit. I used one years ago on a hornet with a ducted fan tail with a gy 240 and a gws 12v motor, it worked very well, and held rock solid!
aaronredbaron is offline Find More Posts by aaronredbaron
Old May 22, 2006, 01:23 AM
b7gwap is offline
Find More Posts by b7gwap
It's Prime Time for Slime Time
b7gwap's Avatar
Joined May 2004
So if you've got an esc for the main motor, and an esc for the tail, how do both get power from the battery? Do you just make a Y-connection or would this blow something up? I'm trying to set up a CP2 on separates.
cheers
Austin
b7gwap is offline Find More Posts by b7gwap
Discussion Give up on my Corona? tr6_guy Electric Heli Talk 17 Sep 04, 2006 08:18 AM
Discussion I'm almost ready to give up on my BCP Mattie Elizabeth Micro Helis 6 Aug 02, 2006 02:49 PM
Please Help:i Dont Wanna Give Up On Jets! submarco Pusher Prop Jet Models 24 Dec 08, 2005 10:54 AM
Help! help me please, about to give up on RC flying xoon Parkflyers 60 Feb 03, 2005 07:18 PM
About ready to give up on CD-ROM conversions... papasmurf Power Systems 20 Jul 20, 2004 09:29 PM
